Cylinder head help.
I recently let my local machinist rebuild a set of 2.7 heads for me. He is good at what he does, and said that he had done some Porsche work in the past, and was comfortable doing them. My mistake. 5 of the heads look real nice, but I think he had trouble chocking one (probably the first one) up straight in the mill when he was cutting the head/cylinder sealing surface. The sealing surface is clearly not parallell with the cam housing surface, and I am wondering if he removed equal ammounts of material on the other 5 heads that look O.K.. I guess I will need at least one head. How do I go about measuring up the other 5. I assume there is a maximum ammount of material that can be removed before the combustion chamber becomes to small. I think I already knew better, but gave him a chance any how. I am glad it is my motor and not a customers. Any advice, I think I will give henry a shot,
No left turn un stoned |
Try not, Do or Do not
The proper way to machine the heads is with a fixture in a lathe.
Porsche calls for .25mm maximum to be removed from a head but you can get away with a little more. You just have to compensate for the material with thicker base gaskets. The thicker base gaskets mean more deck height which offers it's own set of issues. You might be better off starting with a new set of heads. 2.7 heads are relatively easy to find and generally cheap. At the very least it sounds like you need one replacement head. Call, I may have what you need.
Henry Schmidt SUPERTEC PERFORMANCE Ph: 760-728-3062 Email: supertec1@earthlink.net Last edited by Henry Schmidt; 11-04-2006 at 07:38 AM.. |
