Stressed Member
Scott Clarke's Avatar
My 2.5 Motor All Pretty
At long last, my motor is more or less done. I thought I'd show it off, and also thank all of you for the help I so desperately needed. I couldn't have done it without this board, several thoughtful and generous and highly skilled members of the Porsche community, and Wayne's book. Here are some brief specs: Short stroke 2.5, late 7R case, '70 spec E cams, JE pistons with reconditioned cylinders, CR measured @ 9.7:1, S spec head ports, Eurometrix rebuilt throttle bodies enlarged to S spec, mag stacks enlarged to '69 S spec, SC oil pump.
The car is not ready for the motor, so it will be a while before I can report on the function of the thing. Thanks, again, to all of you who answered my questions, scrounged around for parts, and shared their own successes and failures for the benefit of the rest of us.
-Scott
'70 911E short stroke 2.5 MFI. Sold
'56 Cliff May Prefab
Old 12-04-2006, 08:00 AM
Super Moderator
cstreit's Avatar
Very nice Scott. You must be a proud Papa now!
Chris
1996 993 RS Replica
2023 KTM 890 Adventure R
1971 Norton 750 Commando
Alcon Brake Kits
Old 12-04-2006, 08:45 AM
shbop's Avatar
Very nice Scott! How did you treat your fan and housing?
Jon
Old 12-04-2006, 09:26 AM
Stressed Member
Jon-
The fan and housing are powder coated a color that was called "light bronze." It has a pebbled finish. I thought that it would look nice, and realized when the motor was together that it matches the color of freshly bead blasted magnesium almost perfectly. My fan and housing were badly pitted, so the pebble finish was great for hiding less than perfect parts.
Old 12-04-2006, 09:40 AM
356RS's Avatar
A beautiful job done Scott. Keep us posted.
Mark Jung
Bend, OR
MFI Werks.com
Old 12-04-2006, 10:21 AM
shbop's Avatar
Thanks Scott. Very nice.
Jon
Old 12-04-2006, 01:12 PM
Send a message via Yahoo to Lukesportsman
Is this with 2.7 cylinders and early crank?
I think the E cams will be great on the street ( I have E's in my 2.7MFI). The S surely sound sweet and would wind out that short stroke nicely but would be soft on the street.
I forgot to add: WOW it looks great, tempts me to swap the factory cleaner.
Luke S.
72 RS spirit 2.7mfi, 73 3.2 Hotrod on steelies, 76 993 3.3efi TT, 86 trackrat, 91 C4s widebody,02 OLA winning 6GT2, 07 997TT, 72 914 v8,03 900 rwhp 996TT
Old 12-04-2006, 05:12 PM
Stressed Member
Thanks to all for the kind words.
Luke-
Yes, I should have mentioned that it is the 66mm crank from my '70E donor motor, which is where most of the parts came from. I'm glad to hear that your E cams work well in your 2.7. I did the ports so that in the future, if I decide I need to, I can change cams without removing the heads again, and have ports well matched to displacement and cams.
Old 12-04-2006, 05:37 PM
Scott,
Damn fine work! That is a peice of art. Now it needs to be broken in. As your car is not ready, I'd be happy to volunteer to put it in one of mine and get it ready for you .
Brooke
Brooke
1969 911 ST 2.8SS EFI ITB (Irish Green), 1974 911 3.6 ITB (Black)
1952 MG TD with F20C
Old 12-04-2006, 09:07 PM
randywebb's Avatar
Hey Scott- nice! Take another pic of your fan - it looks a LOT nicer than the one above shows.
It would be a shame to use that motor to drive with and get it all dirty...
"A man with his priorities so far out of whack doesn't deserve such a fine automobile."
- Ferris Bueller's Day Off
Old 12-05-2006, 03:44 PM
