930 pistons without a turbo?
I'm considering replacing the p&c on my 82 3.0 with 3.3 liter turbo p&c. I'm using a 3.2 intake with EFI so I don't really need the CIS style pistons.
Will the cylinders fit my case and heads? Will the wristpins fit my rods? Anything else I need to think about? Any idea what compression ratio I'll end up with?
Thanks!
>>> jd
1982 911SC
Old 12-09-2006, 11:17 AM
3 restos WIP = psycho
kenikh's Avatar
Don't do it. 7.5:1 CR will make your car respond like a Geo Metro.
- 1969 911S
- 1980 911SC Targa
- 1979 930
Old 12-09-2006, 11:27 AM
Try not, Do or Do not
Henry Schmidt's Avatar
Short stroke (70.4 vs 74.4) and higher wrist pin location will give you a compression ratio closer to 6:1.
Henry Schmidt
SUPERTEC PERFORMANCE
Ph: 760-728-3062
Email: supertec1@earthlink.net
Old 12-09-2006, 02:49 PM
Thanks for the info. Sounds like even if I put a turbo on it, the combination of an SC crank and turbo pistons would not give enough compression.
>>> jd
1982 911SC
Old 12-09-2006, 03:58 PM
If the rods are rebuilt for a 23 mm wrist pin and with a .80mm offset you can get the compression back. this combination makes a 3.12 liter turbo with nice performance.
Henry Schmidt
Ph: 760-728-3062
Old 12-09-2006, 04:18 PM
That sounds interesting. So I guess there are no other compatability issues with the case or heads. Should any good machine shop be able to mod the rods? Would a 964 cam be a good choice?
>>> jd
1982 911SC
Old 12-09-2006, 05:10 PM
I have some 930 P&Cs if you need any. !!!! really cheap
henry covered everything else I was going to say
Ben
89 944,85.5 944
914-6 2.4s GT tribute.
914-6werkshop.com
Old 12-09-2006, 05:42 PM
Send a message via Yahoo to Lukesportsman
Henry won't shout out for himself, but I'd consider him. Be careful with local machine shops in that they often work in thousands of inches and not necessarily metric offset bushings.
Sure, I would say that any good Porsche shop should be able to do this, but certainly ask questions.
Luke S.
72 RS spirit 2.7mfi, 73 3.2 Hotrod on steelies, 76 993 3.3efi TT, 86 trackrat, 91 C4s widebody,02 OLA winning 6GT2, 07 997TT, 72 914 v8,03 900 rwhp 996TT
Old 12-09-2006, 09:58 PM
