Rickw96's Avatar
Smile New guy looking for help in SLC
Hello,
First time poster. I just acquired a 1984 911 with a bad engine? It runs but crappy. Not sure if a engine rebuild is required. If required anyone in the Salt Lake City area willing to help with a rebuild? Thanks in advance for any help.
Rick
Old 12-11-2006, 05:26 AM
Rick,
Welcome to our BBS. If you have some experience with engines, my first advice is to get a compression gauge and check your motor out.
The crappy running could be internals or something not as serious.
If the comps for all six cylinders are all within 10% of each other, I would look at ignition wires, rotor, cap, plugs. Then the mass air sensor signal. Head temp sensor and the 2 flywheel sensors.
If you're not familiar with engines, you may want to check aroung SLC for a independent Porsche shop. Get in touch with the local PCA people, they can recommend trustworthy people.
DOUG
'76 911S 2.7, webers, solex cams, JE pistons, '74 exhaust, 23 & 28 torsion bars, 930 calipers & rotors, Hoosiers on 8's & 9's.
'85 911 Carrera, stock, just painted, Orient Red
Old 12-11-2006, 08:58 AM
Rickw96's Avatar
2.7racer thanks for the info. It starts fine and idles great but as soon as I give it some gas a load cluck starts like a bad rod bearing??? I am confused because no strange noise at idle.
Old 12-11-2006, 08:03 PM
Air Medal or two
afterburn 549's Avatar
I am all for the KISS method..Like said -dont jump conclusions, do a Comp check- tell us what ya get . We all will help you threw a diagnostic so you will know , hope fully rather then guess......that can be $$
162 Assault Helicopter Co,(Vultures ) D troop 3/5 Air Cav. ( Bastard CAV) South of Saigon, U Minh Forest, Delta, and most parts in between.
Old 12-11-2006, 09:57 PM
Rickw96's Avatar
I agree. I will do the check and get back. Thanks
Old 12-12-2006, 04:14 AM
Rick
call Les at air power racing in ogden. Best air cooled shop west of the Mississippi..He's very fair and will save you a ton of time..
Matt
BTW did you buy the silver car off craigslist?
Old 12-25-2006, 04:18 PM
Rickw96's Avatar
Matt,
Thanks I will give him a call. Yes that's the one, its in good shape. The body is straight and interior is ok. I will try to drop the engine this week.
Rick
Old 12-25-2006, 06:04 PM
