OCD project capitan
Lets play "ID THE CAM GAME!!!" Yay!
Hello all,
I was hoping someone could help me identify these cams... I'm told they are a 908 grind (but obviously for a 911 with the four bearing 911 cam housings). The engine I picked up was a '72 2.4L with 92mm Mahles making it the 2.8L, stock 33mm intake port and 32mm exhaust port heads, MFI with a modified pump. I'm told it all worked really well together. Part numbers are 911.105.137&138.0R ![]() I slapped these on the lathe and with a dial indicator it showed these have .450 lift and an obvious impressive duration. ![]() Thanks, Don.
Don Welch '73 914ish ->6ish GTish 2.8 twin plug mfi... happy camper. |
Those are 3.0 RSR cams.
Steve Weiner Rennsport Systems Portland Oregon (503) 244-0990 porsche@rennsportsystems.com www.rennsportsystems.com |
OCD project capitan
OOOOOO!!!! Thanks for the input Steve!
