piston reference
2.2l t,e,s, pistons
how can I tell a difference
dave
Gemini Blue 73.5 911 T Sold
1994 C4 Widebody Sold
Old 01-07-2007, 07:06 PM
Dave,
The S pistons are Mahle, the piston is not fully skirted. That is, the piston skirt is open at the sides where the pin is inserted.
The S piston is lighter than the E and T pistons which are fully skirted.
The S piston weighs about 354 grams as compared to 371/376 grams for the E and T pistons.
S is 12.48oz. E is 13.08oz. T is 13.26oz.
The S piston were made slightly smaller diameter for greater piston to cylinder clearance. 83.95, 83.96 and 83.97mm.
Where the T and E pistons were made 83.97, 83.98 and 83.99 mm.
Kolbenschmidt made only the T pistons.
This info from the factory manual.
DOUG
'76 911S 2.7, webers, solex cams, JE pistons, '74 exhaust, 23 & 28 torsion bars, 930 calipers & rotors, Hoosiers on 8's & 9's.
'85 911 Carrera, stock, just painted, Orient Red
Old 01-08-2007, 10:31 AM
Doug many thanks.
Old 01-08-2007, 03:23 PM
