Kevin G.'s Avatar
3.0 Turbo crank same as 2.4 crank?
I need a crankshaft for a 2.4 motor I will be building, and came across a 3.0 turbo crank that the owner says is interchangable the 2.4 / 2.7 crank.
Just need verification from someone who knows.
Thanks!
Kevin
Kevin G.,
'72 T Targa
Old 01-09-2007, 09:47 AM
They are supposed to be the same. One quick way to check that it is probably the right one is to count the flywheel bolts. The 2.4/2.7 crank has a smaller flange with 6 bolts as opposed to the SC and later crank having a larger flange with 9 bolts.
-Andy
Old 01-09-2007, 09:57 AM
same.
206 637 4071
Old 01-09-2007, 10:39 AM
Same crank.
Old 01-10-2007, 07:00 AM
