jluetjen's Avatar
When you said "Race motor", my first question is where? If you want to race, you had better read the rules first regarding what is allowed before you start building anything.
If you're talking about a rev-happy motor for DE'ing, then you're asking the right set of questions. But if you're talking about racing, there will be no end to the pain and suffering if you show up to race somewhere, only to discover that the car isn't legal.
John
'69 911E
"It's a poor craftsman who blames their tools" -- Unknown
"Any suspension -- no matter how poorly designed -- can be made to work reasonably well if you just stop it from moving." -- Colin Chapman
Old 01-19-2007, 01:11 PM
Stahlwerks.com
jhelgesen's Avatar
Send a message via Yahoo to jhelgesen
I think if I were to race the car, it would be with NASA, do the dyno/weight thing. No way I could do PCA as much a bastard my car is.
John Helgesen
Stahlwerks.com restoration and cage design
"Honest men know that revenge does not taste sweet"
Old 01-19-2007, 01:22 PM
Stahlwerks.com
jhelgesen's Avatar
Engine update....
Since this started, I aquired a parts car with a hot 3.0 in it.
Got the weber 46's and a euro sc dizzy now.
I'll be diving in further to the new motor to check pistons, cylinders, and cams, see what else it has for me.
Might be able to swap long blocks if good, or use the two 3.0's to make one hot rod, one stock.
More info to come.
John Helgesen
Old 08-04-2007, 05:38 AM
shbop's Avatar
Originally Posted by ChrisBennet View Post
The very first thing on the list would be stiffer valve springs. They won't make you go faster but it might keep you from going home on a trailer if you miss a shift.
-Chris
Too Good!
Jon
Old 08-04-2007, 08:03 AM
Stahlwerks.com
jhelgesen's Avatar
Installed the dizzy in my car yesterday, checked the timing, 35 degree advance somewhere around 3-4k (hard to see timing light at tach at same time), sounded pretty good.
John Helgesen
Old 08-06-2007, 09:39 AM
Porschekid962's Avatar
Send a message via AIM to Porschekid962 Send a message via Yahoo to Porschekid962
3.0 base motor
Jenvey taper bore throttles
Autronic EFI
993 twin plug dizzy
DR camshafts
JE pistons 100mm bore
LN nickies 100mm bore
DR springs and retainers
stock 3.0 heads
stock rods
stock pump
solid tensioners
gt2 evo chains
twin plug
bosch ms injectors
pump gas
arp rod bolts and headstuds
got 298.5 rwhp at 6500rpm and a tad over 200hp
The run was cut short but the cams make power to 8500rpm.
It is quite the tq monster. If I were to do it again though I would have sold the 78 sc base motor and started with a 3.2 just for the larger stock heads. The engine is slated to be changed again within two years depending on the mileage it racks up.
Changes are bigger heads, custom rods, custom pistons, modded crank, bigger oil pump, coil on plug, no dizzy, different cams, different valves and some other little touches here and there.
There are so many engine combos you can build, you can build to a class, a budget or to a hp output. Remember though, have tons of fun, to it once and do it right.
74 911s neverending story. two feet and a jetta for now.
Old 08-06-2007, 05:43 PM
