How to remove clutch/pulley from York AC compressor?
I'm rebuilding my '82SC engine. Right now, the engine is apart and I'm going thru all the parts cleaning and sand/bead blasting away. I'd like to take the clutch off of the AC unit (York) so I can better clean all the crevices around it and bead blast the outside.
I was able to remove the bolt that appears to fasten the outer clutch plate, but the plate doesn't budge with the bolt removed and there isn't really any where to get a grip on it. Has anyone had the clutch off their York compressor?
Thanks.
Geoff
'82 911SC (Complete rebuild)
Click here to go to the project website that chronicles the rebuild process
Old 02-01-2007, 05:58 PM
Scott R's Avatar
I did this last summer to replace the shaft seal, you need a wide three jaw puller, or better yet borrow an AC clutch puller from your local Checker.
2021 Model Y
2005 Cayenne Turbo
2012 Panamera 4S
1980 911 SC
1999 996 Cab
Old 02-02-2007, 05:06 PM
Does the pully come off with the outer clutch plate or do they come off separately?
Thanks.
Old 02-02-2007, 05:27 PM
Scott R's Avatar
Thanks.
They are separate, however I pulled them off all at once, the other clutch plate slid off with the main plate and magnet.
2021 Model Y
2005 Cayenne Turbo
2012 Panamera 4S
1980 911 SC
1999 996 Cab
Old 02-02-2007, 05:48 PM
rsscotty's Avatar
It has been a while, but if my memory serves me correctly, when you take out the bolt that holds the clutch to the compressor, there are a larger set of threads in the clutch for a removal tool to be threaded into. York used 2 different bolts for clutch removal.
They were 5/8- 11 thread and 5/8- 18 thread. I don't know what one fits your application.
Hope this helps.
Old 02-02-2007, 07:29 PM
