purplehaze's Avatar
Removing wrist pin BUSHINGS
OK, so I used the wrong word before.....
Hi,
I'm writing for a friend an an 80 euro SC doing a top end rebuild.
He doesn't want to split the case and would like to press out the wrist pin bushings while the connecting rods are still attached to the crank. The pistons are removed.
He's tried a simple press (think C-Clamp or threaded rod with sockets as a press) but they're not moving.
Any ideas? Can you do this without taking them out to a real press?
Thanks,
Glenn
Glenn
87' 930TT
Old 02-10-2007, 12:10 PM
Jeff Alton's Avatar
You can take the rods out without splitting the case....
Cheers
www.turn3autosport.com
Old 02-10-2007, 12:18 PM
I custom made a tool that fit perfectly into the wrist pin and allowed enough clearance to press on the bushing and still push all the way through. I had to use a hefty arbor press; a vise alone is not enough. You will need an extension bar as well to help push the bushing tool through, all of mine made a large sound once they loosened up. Go slow and don't get too frustrated and end up damaging them.
Alex
Its easier asking dumb questions than fixing dumb mistakes
1974 Porsche 911 Coupe, RSR Project
1976 Porsche 911 Targa, Black
1986 Porsche 911 Carrera, Black
2006 Porsche Cayenne S, Black
Old 02-10-2007, 02:08 PM
purplehaze's Avatar
Thanks guys! It looks possible but not easy.
Catca - that's what I told him but he didn't want to replace rod bolts. They were recently done.
Alex - thanks. I'll tell him to use more force (arbor press) and to just have more patience. Thanks a lot. love your tag line!
Glenn
Glenn
87' 930TT
Old 02-10-2007, 02:34 PM
small end bushings
How are you going to machine the bushings ?
Mike
The two most useless things to a driver are the braking distance behind you and nine-tenths of a second ago.
Old 02-18-2007, 04:52 PM
