1972_911T's Avatar
3.2 Cylinders 3.0 Crank
Can 3.2 cylinders be used with a 3.0 crank to make a 3.0 or due to the shorter stroke will this result in a compression drop?
1972 911t RS Styled
G50 conversion underway
1972t Resto Project - http://www.ddk-online.com/phpBB2/viewtopic.php?t=16695
Old 02-21-2007, 10:27 AM
Hi Steve..what pistons and rods did you plan?
The 3.2 rods are not really much good..its much cheaper and better to start with a SC motor if you must have 3.0 litres..
Kind regards
david
Old 02-21-2007, 10:43 AM
1972_911T's Avatar
Hi David going with 3.0 rods and probably JE pistons.
1972 911t RS Styled
Old 02-21-2007, 11:02 AM
The only difference between the 3.0 SC cylinders and the 3.2 cylinders is the sealing ring and groove used on the SC. Porsche eliminated the sealing ring on the 3.2 motors and these cylinders can be used for a 3.0 application without the sealing ring.
Tom Butler
1973 RSR Clone
1970 911E
914-6 GT Recreation in Process
Old 02-21-2007, 11:25 AM
