3.2 Cylinders 3.0 Crank
Can 3.2 cylinders be used with a 3.0 crank to make a 3.0 or due to the shorter stroke will this result in a compression drop?
1972 911t RS Styled G50 conversion underway 1972t Resto Project - http://www.ddk-online.com/phpBB2/viewtopic.php?t=16695 |
Hi Steve..what pistons and rods did you plan?
The 3.2 rods are not really much good..its much cheaper and better to start with a SC motor if you must have 3.0 litres.. Kind regards david |
Hi David going with 3.0 rods and probably JE pistons.
The only difference between the 3.0 SC cylinders and the 3.2 cylinders is the sealing ring and groove used on the SC. Porsche eliminated the sealing ring on the 3.2 motors and these cylinders can be used for a 3.0 application without the sealing ring.
Tom Butler 1973 RSR Clone 1970 911E - Sold but Never Forgotten 914-6 GT Clone |
