Less brakes, more gas!
euro911sc's Avatar
Angry Holy RTV Batman!!
I'm sorry, but is a whole tube of RTV really required??
... and could you believe that the left side was way worse!! There was a pool of the stuff sitting in the bottom of the chain housing!! Its all over the cam carrier to head mating surfaces too...
What happens when RTV gets into the oiling circuit?? Wait, don't answer that... I don't think I want to know...
*sigh*
-Michael
Michael
'82 Euro SC 'Track Rat' 22/29 Hollows, 22/22 Tarrets, Full ERPB F/R, Rennline Tri Brace, Glass bumpers, Pro 2000's, 5 pts, blah blah blah
'13 Cayenne GTS
Old 10-26-2005, 09:52 PM
I hate freight charges
village idiot's Avatar
Send a message via Yahoo to village idiot
I hate that stuff too. To me it's the sign of a hack mechanic. Don't get me wrong I use it on occasion but I use as little as possible.
If you have two nicely machined surfaces and a quality gasket then there shouldn't be any need for a sealant...
Tom
78 911SC SC to 73RS imposter SCWDP crew #50 and 51
1969 Camaro "The new project"
Old 10-27-2005, 12:25 AM
Wer bremst verliert
JohnJL's Avatar
Except that Pelicen Part Rebuild Kits come with Black RTV, right Wayne ;-)
2007 911 Turbo - Not a toy
1985 911 Cab - Wife's toy
1982 911 3.2 Indiash Rot Track Supercharged track toy
1978 911 3.0 Lichtbau toy "Gretchen"
1971 911 Targa S backroad toy
Old 10-27-2005, 02:41 AM
Warren Hall Student
Bobboloo's Avatar
The use of RTV on a through bolt o-ring is a valid solution when a through bolt case hole is out of round.
Bobby
_____In memoriam_____
Warren Hall 1950 - 2008
_____"Early_S_Man"_____
Old 10-27-2005, 11:13 AM
Wer bremst verliert
JohnJL's Avatar
Sorry Wayne, meant it good humor of course. Bad day.
Old 10-27-2005, 01:08 PM
Try not, Do or Do not
Henry Schmidt's Avatar
Re: Holy RTV Batman!!
Originally posted by euro911sc
What happens when RTV gets into the oiling circuit?? Wait, don't answer that... I don't think I want to know...........
Very small pieces of red crap travel through your engine and stop at the smallest openings.
Rod bearings, main bearing, piston squirters and cam tower spray bar. All are bad and all those circuits must be cleaned out.
When you start looking, it will amaze you where those little red worms will nest.
Henry Schmidt
SUPERTEC PERFORMANCE
Ph: 760-728-3062
Email: supertec1@earthlink.net
Old 10-27-2005, 03:34 PM
Wer bremst verliert
JohnJL's Avatar
I think I just "made the list..."
Old 10-28-2005, 07:20 PM
dion914-6's Avatar
That's what my chain covers looked like too!
When I got down to the oil pump and removed it, it wouldn't turn very easily at all and felt like it was almost frozen up. I took it apart only to find large pieces of orange, hardened RTV in between the gears.
That stuff is the kiss of death...
Dion
Old 10-28-2005, 07:42 PM
Still Doin Time
asphaltgambler's Avatar
You NEVER use any RTV WITH a paper gasket. From the picture above, the former 'technician' doesn't even grasp proper gasket sealing technology.
I'm suprised that he/they had enough sense to know where the cam covers were.
Old 10-30-2005, 06:04 AM
euro911sc's Avatar
Basically, with all the unfortunate things I am finding in my motor I'll be taking every single screw, nut, and assembly apart and cleaning it...
I guess this will now include the oil pump...
Is it hard to disassemble and re-assemble?
-michael
Michael
'13 Cayenne GTS
Old 10-30-2005, 09:49 AM
Warren Hall Student
Bobboloo's Avatar
Yeah, so the motor blew, but it never leaked.
Bobby
Old 10-30-2005, 09:51 AM
Still Doin Time
Now THAT'S funny!!
Old 10-30-2005, 09:56 AM
Irrationally exuberant
ChrisBennet's Avatar
-michael
It's not hard. Put the gears back together with the same orientation if you can. Both impeller gears have the same number of teeth (10?) and each tooth has been meshing with the same "valley" on the other gear since the the pump was put together.
-Chris
'80 911 Nogaro blue Phoenix!
'07 BMW 328i 245K miles!
Old 10-31-2005, 04:14 AM
1yearonLy's Avatar
I found what looks to be similar stuff on the valve covers and the chain cover areas. It isn't hardened though, it's gummy whether in or outside of the motor. Is it the same stuff?
Scott Perry
2004 VW Golf TDI
1974.5 MGB GT
Old 11-01-2005, 10:39 AM
euro911sc's Avatar
It will be soft and pliable and stretch like a rubber band if its RTV. If you pull hard enough it will snap at some point and you will have collected a small bit in your hand. It has the consitantcy of silicone bathroom caulking. You can trim it off with a razor if you like.
It also makes getting the chain covers and housings off very difficult...
-Michael
Michael
'13 Cayenne GTS
Old 11-01-2005, 08:01 PM
1yearonLy's Avatar
Yes, I must have RTV on there. The valve covers were stuck on there pretty good with the stuff. It took me a while to get every last bit of the stuff off but I did. It wasn't smeared all around the inside of the heads (valve train area)...it was contained to the sealing area so I wasn't too worried..
Should I just leave it alone as far as the chain housing covers are concerned? They don't leak and it's been this way for 11 years and 25k miles give or take.
Thanks.
Scott Perry
2004 VW Golf TDI
1974.5 MGB GT
Old 11-02-2005, 06:56 AM
euro911sc's Avatar
Scott,
See Bobboloo's post... hehee
I'm already tearing the engine down completely so my covers/housings had to come off anyway. The usage on my engine was beyond rational, but if you dont have excessive amounts in the chain housings you may be ok... but, this is my first engine rebuild ever so your call
-Michael
Michael
'13 Cayenne GTS
Old 11-02-2005, 07:57 AM
1yearonLy's Avatar
It's been that way for a while and it wasn't a real sloppy job, my feeling is to leave it alone until I need to get in there for something.
There are so many 'what ifs' that sometimes I need to step back and take it as it comes.
Good luck with your rebuild. It sounds like a great adventure!
Scott Perry
2004 VW Golf TDI
1974.5 MGB GT
Old 11-02-2005, 08:05 AM
euro911sc's Avatar
And the uglyness continues...
Cam carrier to head mating surface:
*sigh*
-Michael
Michael
'13 Cayenne GTS
Old 11-12-2005, 11:16 AM
