126coupe's Avatar
Twin Plugging the 2.0L
After being very pleased with twin plugging my 2.5L and upping the camshafts from DC 60 to DC 80 I decided to do the same to the 2.0L
Should have the Cams back from Dougherty in a week or so.
The heads will be done in a few days.
The Distributor and wires and clutch package will come in 2 weeks from JB Racing.
I decided instead of swapping distirbutor and wires from the 2.5 to the 2.0 both engines will have their own systems.
The only thing that I need to swap are the intake and carbs.
The 2.0L will benefit greatly from twin-plugging.
1967 911R "Clone" Race Car 2.0 & 2.5 Twin Plug
1984 Mercedes 500 SEC
1991 Mercedes 420 SEL
1992 Ford F-350 Dually
28' Pace Trailer
Old 02-28-2007, 02:13 PM
Twin Plug?
Saw pic's of your last twin-plug motor . . . and turned green with envy. I'm building a 2.5SS/DC60 motor right now. . . mind if I ask what the measurable difference was with the twin-plug setup. I think you converted from single-plug, right? Why did you do it?
I'm just about ready to pull the trigger on getting my heads worked. I've ruled out a twin-plug just because I could not clearly see the advantage to spending the dough. I'm going to run 89mm 10.3:1 Mahles which will probably be less than that when it's all done and I'll be running this on pump gas. My thoughts are that I may have to play with the timing advance, just a little, if at all.
I know Mark Scott is running a single-plug too, but he's running his motor on race gas.
Your thoughts on this would really be great right now, since it's not too late for me to change my mind.
Thanks,
Tom
Tom Ching
69 911E
Old 02-28-2007, 06:32 PM
Tom:
If I might say,..........I would reconsider your thoughts about trying to safely run 10.3:1 on 91 octane fuel using single-ignition.
That might carry some expensive consequences regardless of how much total timing you use.
Steve Weiner
Rennsport Systems
Portland Oregon
(503) 244-0990
porsche@rennsportsystems.com
www.rennsportsystems.com
Old 02-28-2007, 07:37 PM
Hey Steve . . . thanks for the input. I sent you an email so I don't hijack this thread.
Tom Ching
69 911E
Old 02-28-2007, 10:58 PM
126coupe's Avatar
Originally posted by Noah
Minkoff,
Can you tell us about the twin-plug distributor you decided on? I went to the JB Racing website and I can't tell if the distributor, for $1,500, comes with the cap and rotor or not. Is this the same distributor that Supertec makes? Any other thoughts/experiences about it?
Yes it comes w the cap and rotor. I tested the system at Buttonwillow and was amazed at the performance, but I also put in a hotter cam and JB Racing lightweight flywheel/clutch system.
28' Pace Trailer
Old 03-01-2007, 09:15 AM
Grady Clay's Avatar
Minkoff,
Twin-plug your 2.0 will make a great difference. It is worth the effort.
Best,
Grady
ANSWER PRICE LIST (as seen in someone's shop)
Answers - - - - - - - - - - - - - - - - $0.75
Answers (requiring thought) - - - - $1.25
Answers (correct) - - - - - - - - - - $12.50
Old 03-01-2007, 12:49 PM
126coupe's Avatar
Got the heads back from the machine shop, refinishing some parts, laying out all the gaskets and seals. Waiting on the cams so I can perform my piston to valve clearences.
28' Pace Trailer
Old 03-03-2007, 06:50 AM
126coupe's Avatar
Twin Plug 2.0L continued
Dry fitting everything for my piston to valve clearences.
Assembled fan...........no powder coating!
Chased all threads with tap and dye.Time consuming but worth the effort.
28' Pace Trailer
Old 03-07-2007, 07:19 AM
126coupe's Avatar
Fitted the clutch/flywheel and Distrib.
Just waiting on the cams
28' Pace Trailer
Old 03-29-2007, 02:42 PM
