1972_911T's Avatar
Which Case
Im faced with a minor dilemma, im building a 3.0 MFI street motor and have the option of 2 cases the first is an 89 3.2 the second is an 1980 SC. Both cases are in good condition, which would best suite the purpose I believe the 3.2 is stronger but with the power im planning I dont think this is much of an issue. The only other difference is the SC is about 3kg lighter.
1972 911t RS Styled
G50 conversion underway
1972t Resto Project - http://www.ddk-online.com/phpBB2/viewtopic.php?t=16695
Old 03-02-2007, 06:40 AM
Try not, Do or Do not
Henry Schmidt's Avatar
It's a toss up.
There is no benefit from one to the next until you make 400+ hp.
The 3.0 would look more period correct if that has any meaning to you.
If you are building a long hood car, the 3.0 case can be made to closely resemble the mag case.
Here is the 3.2 short stroke MFI we just built.
Henry Schmidt
SUPERTEC PERFORMANCE
Ph: 760-728-3062
Email: supertec1@earthlink.net
Old 03-02-2007, 12:42 PM
1972_911T's Avatar
Ok I think ill go with the SC case will a 3.2 oil pump work in an SC case will the sump cover? Is there an advantage to the 3.2 pump over the 3.2?
1972 911t RS Styled
Old 03-02-2007, 12:54 PM
Henry,
Your engines are so ugly! Why don't you try to pretty them up a little
-Andy
Old 03-03-2007, 06:47 AM
