Whats with all these #'s on my 2.7??
Here you see 9011051111R and then under the motor there is 911-101-101-7R
911-101-102-7R
I though it was a 74 2.7 but I dont know what these mean.
Also This was a great running motor, just looked dirty. What could I check for (Headbolts) before I reassemble??
Is this a better than stock clutch??
1981 Delorean
Old 03-12-2007, 08:08 PM
andrew15's Avatar
Those are all casting #'s for the various pieces of the engine.
Look for 2 numbers in the highlighted area below:
- There should be the engine number stamped into the vertical fan support
- The engine type is stamped on the horizonal surface near the oil pressure switch
Post those two numbers and it will be easy to decipher.
Regards,
Andrew M
1970 911E - track / weekend car
1970 911S - under restoration
1986 930 Slant Nose - fun car
Current used parts for sale
Old 03-13-2007, 05:33 AM
here they are
1981 Delorean
Old 03-13-2007, 11:36 AM
andrew15's Avatar
These #'s show 1976 49State US 2.7 engine - hope that helps.
AM
Old 03-16-2007, 07:49 PM
