Porsche Junky
mede8er's Avatar
What would Henry Schmidt do......
So....I pulled then engine on my cream puff 82 SC (2nd owner, 65k miles) to reseal it. (Had a gusher from driver side cam tower). When I pulled the valve covers I found 2 head studs in there....
So....my question is what can you do to a 3L to improve performance? Change outP & C's to allow for bigger cams? Stroke it?
I have a set of 40 PMO's to finish this project...
1986 930 RUF equipped
Old 03-28-2007, 07:21 PM
Does the car need to pass smog tests?
Is it going to be a street car?
Whats your budget?
A properly-cammed, 3.2 litre motor with PMO's and a proper exhaust can be made to run VERY well.
Twin-ignition would be a big plus.
Steve Weiner
Rennsport Systems
Portland Oregon
(503) 244-0990
porsche@rennsportsystems.com
www.rennsportsystems.com
Old 03-29-2007, 12:33 AM
Send a message via AIM to fintstone
I'm not sure about the rest...but I guarantee that Henry would use Supertec head studs.
74 Targa 3.0, 89 Carrera, 04 Cayenne Turbo
http://www.pelicanparts.com/gallery/fintstone/
"The problem with socialism is that you eventually run out of other people's money"
Some are born free. Some have freedom thrust upon them. Others simply surrender
Old 03-29-2007, 01:05 AM
Porsche Junky
mede8er's Avatar
Well Steve...you pretty much hit the nail on the head for what I was considering...we do get 93 octane down here in Floriduh.....
But I think the cost would put me back to another 3.6 conversion....not that there's anything wrong with that......
Fint, the Supertecs are definitely on my list...
Old 03-29-2007, 08:32 AM
Try not, Do or Do not
Henry Schmidt's Avatar
If your budget is like mine, here's what I would do.
With 65K on the engine you can count on reusing the pistons and cylinders. Hoping they are Mahle Nikasil
I would put valve pockets in your 9.3 :1 cis pistons, DC40 cams w/John's springs, port intakes to 39mm and install your 40mm PMOs and SSI exhaust and M&K muffler. 240+ hp
Head studs are optional but I appreciate the plug. With an engine like this you could just replace the Delivar with steel studs.
Now if you have a budget like the Pentagon, 3.2 short stoke, Carrillo rods, ported to 40mm, ty valves, DC80 cam w/Supertec valve springs and ty retainers, Supertec twin plug, Supertec stainless steel exhaust, M&K muffler, Aluminum flywheel, custom built MFI and of course Supertec head studs. 320+ hp.
Henry Schmidt
SUPERTEC PERFORMANCE
Ph: 760-728-3062
Email: supertec1@earthlink.net
Old 03-29-2007, 10:37 AM
911 tweaks's Avatar
Henry, what else can be said other than...
"you are THE picaso of porsche 911 engines"
Bob
I live for 911 tweaks...
Old 03-29-2007, 11:12 AM
Porsche Junky
mede8er's Avatar
Ask and ye shall receive...Thanks, Henry....
I need to call my congressman and see if he can get me in that mass appropriations bill.....
Old 03-29-2007, 12:22 PM
what are the cost estimates?
Henry,
Can you provide any general estimates on the total costs for the two engines? Sourced from you?
thanks much
marlin
Marlin Ness
sadly no longer: 1967 912, 1971 911T, 1974 911 Targa, 1975 914, 1972 914 Eagle GT with V8
currently: 1972 914 Eagle GT with 3.2 Carrera, 1970 911T (964 turbo wide body look), 1986 911 Carrera
Old 03-29-2007, 06:43 PM
E-85 sippin drunk
turbobrat930's Avatar
Re: What would Henry Schmidt do......
Since you are in Florida....call Mike Bruns at JB racing....
www.jbracing.com
Brad...930 gt-1 racecar, increased displacement to 3.6L, JB racing Cylinders, JE 8 to1 pistons, stroked crank, Carrillo rods, extrudehoned 3.2L intake, full bay Bell I/C, GT-2 EVO cams, Rarly8 headers, GTX-3584RS turbo, twin plug, P&P heads, Link G4 EFi system, G-50/50 with LTD slip and oil squirters/oil cooler, zork tube, full race coilover system, with carbon fiber body, full cage, E-85 sippin drunk
Old 03-29-2007, 07:31 PM
Re: what are the cost estimates?
Originally posted by marlinaness
Henry,
thanks much
marlin
12k and 20K give or take a few.
Henry Schmidt
Ph: 760-728-3062
Old 03-29-2007, 08:03 PM
cool options and thanks for the plug as well henry. gotts get rolling on thise ss headers see ya!
Ben
89 944,85.5 944
914-6 2.4s GT tribute.
914-6werkshop.com
Old 03-30-2007, 07:20 AM
