Roslin's Avatar
Question Front suspension rebuild..
I have just disassembled the complete front suspension of my car, due to very bad handling !
After all the parts was removed from the car, i tried to inspect every single part, and i relay did not find any critical points - i cant see any defects The front shocks is Bil stein the type ... 5001-HO these have maybe a very minor difference in the feel when they are compressed (the left one is the soft one), and a small clearances in between the shock part/ tube - no oil leaks - the expand by them self as they should.
I think the best way to start is to fit 2 new Bil stein inserts of the same type ( std.) i assume they are ??
Do i need to do something with the guide in the tube, or is it even possible to change something here ?
As the car is lowered i am thinking about moving the spindle the up-wards on the tube, to get fully suspension travel and better geometry in the suspension.
Have anyone tried to move the spindles up on Bil stein struts?
I can se they are welded by one big spot on the back, but i do not know if this is it .. or the are schrinked on the tubes ?
The four rubber bushings in the lower arms looks OK.
After the car has stand on 4 jigs for one year, because of engine rebuild, it would not get the same low ride hight as before (even after 500 miles of driving) - maybe due to friction in the rubber bushings ... and mabye therefore the very bad handling . By bad handling means that the car pulls from left to right as the suspension is decompressed/compressed. Imagine if you are driving on a road with many small hill's so you relay use your suspension from max. compression to full stretched legs .. over-braking problems at the front at low speed or in rain are also a problem!
Any advice are more than welcome!
See normal low ridehight on attached picture.
Regards Roslin
[img]
http://forums.pelicanparts.com/uploads10/P70904731175852445.jpg[/img]
Porsche 911 SC 3.0
Old 04-06-2007, 02:42 AM
Loose nut bhind the wheel
Wrong forum. try 911 tech.
Ed
1970 911S Targa 2.7RS MFI dual plug 10.5:1
1974 260Z SCCA ITS
1998 M3
Old 04-08-2007, 08:54 AM
