wahoofan's Avatar
2.4E mfi set-up on a T motor
I'm sure I have seen this question answered here before, but I can't seem to find it in the archives.
I may have an opportunity to buy a complete E mfi set-up, which I would put on my 2.4T motor. Is this basically a "bolt-on" improvement, or would I need to have a lot of other $$$ work done?
Also, would the above set-up with E cams and higher compression pistons make for a (relatively) low-budget engine upgrade?
I just dyno-ed my stock 2.4T motor on Saturday and hit 132hp and 138lb/ft, so I don't want to change anything major on what seems to be a strong, original motor!
wahoofan
'72 911T Targa
Old 04-16-2007, 07:32 AM
Try not, Do or Do not
Henry Schmidt's Avatar
Cams and pistons would offer far more improvement than the injection system.
The "T" injection is suitable for engines upgrades.
I would be surprised to see any improvement with the injection alone.
Do the pistons (9.5:1) install E or Solex cams, port the heads and enlarge butterflies/stacks and you'll have a great little engine.
Only buy the injection if you have money to burn or want to save it for a future project.
Henry Schmidt
SUPERTEC PERFORMANCE
Ph: 760-728-3062
Email: supertec1@earthlink.net
Old 04-16-2007, 07:58 AM
wahoofan's Avatar
Henry,
Thanks for the quick response!! I may buy the MFI stuff anyway for a spare, if the price is right.
How much horsepower gain would I expect from the modifications listed above? Would I have to change the MFI pump to do this?
Thanks!
wahoofan
'72 911T Targa
Old 04-17-2007, 07:33 AM
It's very hard to quote horse power numbers on a hypothetical engine but my guess is 20-30.
Henry Schmidt
Ph: 760-728-3062
Old 04-17-2007, 07:56 AM
