efhughes3's Avatar
Originally posted by ChrisBennet
I've been heating the stud at the stud to case juncture and twisting them out after a minute using a MAPP gas torch. I've been doing this for years without any problems but I only deal with Aluminum cases.
-Chris
Chris: To you mean directly around the joint where the stud enters the case (where one would spray PB Blaster to penetrate a stuck bolt) ?
Ed Hughes
2015 981 Cayman GTS
6 speed,Racing Yellow
Past:1984 911 Targa (Ruby), 1995 993C2 (Sapphire), 1991 928S4
Old 04-20-2007, 06:31 AM
I welded nuts on them with a MIG, the heat from welding loosens the loctite. On the long ones that I could grab, I just put a bead near the case as a heat source.
Art
'75 911 US Carrera #390
'74 MGB, AH 3000 BN7 V8,
'65 Mustang Fastback, 66 bronco U13
Old 04-20-2007, 01:19 PM
Irrationally exuberant
ChrisBennet's Avatar
Yes.
'80 911 Nogaro blue Phoenix!
'07 BMW 328i 245K miles!
Old 04-20-2007, 09:24 PM
Jeff Alton's Avatar
You are trying to melt the thread locker, not just heat and expand the hole the stud is in. That is why what Chris says makes sense and works.
Cheers
www.turn3autosport.com
Old 04-20-2007, 10:29 PM
efhughes3's Avatar
Just tried Chris' method on one of the studs-it worked like a charm with my not-so-expensive stud puller. It's one of the ones that looks like a sparkplug socket and has three "fingers" that grip the stud. I'll pull the rest tomorrow.
I actually focused the flame on the stud about 1/2" from where it enters the case, then gave it a test turn which didn't require much torque at all. I'll tell you what, it also avoids the squeamish feeling I'm sure I'd get if I was heating the case directly.
Ed Hughes
2015 981 Cayman GTS
Old 04-23-2007, 12:21 PM
some will certainly come out that way. some.
206 637 4071
Old 04-23-2007, 12:42 PM
efhughes3's Avatar
Please don't put the jinx on me!!
Ed Hughes
2015 981 Cayman GTS
Old 04-23-2007, 12:59 PM
MBruns for President
JeremyD's Avatar
I used chris' method. Looking back on it - the longer the breaker the bar - the better. #2 have someone heat while you twist. deliberate movements allow clean removal - impact or jerking breaks studs.
If you break one - cover your case with sraran wrap. Take the 2" of left over stud (or whatever you have left) and dremel a square on the end of the studs. Then find the biggest pair of vice grips, clamp down - heat and turn!
Old 04-23-2007, 06:50 PM
efhughes3's Avatar
All studs out!! Chris' method was painless.....maybe an hour?
Ed Hughes
2015 981 Cayman GTS
Old 04-24-2007, 02:38 PM
