on a 3.2 stock clutch/flywheel parts..stock engine with original crank/etc. - is it good practice to balance the flywheel/clutch asm. separately from the crank? Any comments about good methods/bad methods..? Common ways "machine" shops to this?
Thanks, -h |
From one acknowledged expert:
I plan to use USED flywheel bolts for the balancing process and then when the balancing is done, throw these in the garbage and use NEW flywheel bolts. So that necessitates marking the flywheel and crank so when they are taken apart, you can reassemble them exactly as balanced.
'66 911 #304065 Irischgruen ‘96 993 Carrera 2 Polarsilber '81 R65 Ex-'71 911 PCA C-Stock Club Racer #806 (Sold 5/15/13) Ex-'88 Carrera (Sold 3/29/02) Ex-'91 Carrera 2 Cabriolet (Sold 8/20/04) Ex-'89 944 Turbo S (Sold 8/21/20) |
Try not, Do or Do not
Balance everything separately. that way if you need to replace the flywheel (for example) balancing the flywheel will keep the assembly in balance.
We balance each piece then spin the assembly to check overall balance.
Henry Schmidt SUPERTEC PERFORMANCE Ph: 760-728-3062 Email: supertec1@earthlink.net |
