Cam plate o-ring sealant?
I am replacing the seal and o-ring on my cam plate.
The old o-ring was sealed pretty good with what looked like a white sealant material.
What type of sealant should I use to seal this?
Old 04-28-2007, 07:08 PM
SP2 SP2 is offline
SP2's Avatar
Curil T.
James
1969 911E Slate Grey
1981 911SC Wine Red
1997 911C4S Ocean Blue
Old 04-28-2007, 07:16 PM
thanks!
Old 04-29-2007, 01:12 PM
I install that o-ring with a light coat of silicon grease (Dow 111?). That joint is meant to be able to move due to expansion and contraction of the engine. I don't think a sealant should be used there (even a non curing one).
-Andy
Old 04-29-2007, 02:07 PM
Try not, Do or Do not
Henry Schmidt's Avatar
We also build our engines with oring lubricant (Dow 55) on the oring with Loctite 574 on the gasket.
Although no sealant is necessary Curil T will not hurt.
Henry Schmidt
SUPERTEC PERFORMANCE
Ph: 760-728-3062
Email: supertec1@earthlink.net
Old 04-29-2007, 04:11 PM
Super Moderator
cstreit's Avatar
I've never used a sealant on this, just a little oil. However I'd use Curil-T if I felt the need I suppose. I use it on the gasket but mainly because it helps hold it in place...
Chris
1996 993 RS Replica
2023 KTM 890 Adventure R
1971 Norton 750 Commando
Alcon Brake Kits
Old 04-29-2007, 06:46 PM
