tom2113's Avatar
Advice - R chain tensioner
I have almost completed my chain tensioner update. Prior to tightening the nut I pushed the tensioner in as far as it would go, then tightened the nut. What I am left with is some space between the tensioner and the spacer. (see photo). Is this install okay?
Old 05-01-2007, 04:45 PM
I can't say for sure if this is ok because I have the updated idler arms on mine and I don't remember if there was space like this. Here are some things I would do to satisfy my worries.
Compare the space with this set-up to the space you had with the old tensioner. Push and pull on the idler arm to see how much it moves. I suspect there needs to be some space there so the idler arm can seek the center of the chain travel. The spacer is probably there just to limit the amount the arm can move. Sometimes you can make yourself the expert on these things with some comparison and experimention.
Hopefully someone else with this set-up can confirm that it's correct.
-Andy
Old 05-01-2007, 05:37 PM
that would be normal, as long as it slid in freely and didn't get cocked outward as the nut was tightened.
206 637 4071
Old 05-01-2007, 05:50 PM
tom2113's Avatar
Thanks for both of your comments. The left side went on so easily I did not have an issue.
Thanks again.
Old 05-01-2007, 05:55 PM
Loose nut bhind the wheel
Might consider pulling those tensioners back off and doing the "Jerry Woods" mod as a safety measure in the event of tensioner failure. It is a bit tedious to do it but shoud make those bullet proof. BTW the space is normal if the tensioner is seated proporly on it's mounts. Cheers
Ed
1970 911S Targa 2.7RS MFI dual plug 10.5:1
1974 260Z SCCA ITS
1998 M3
Old 05-01-2007, 08:04 PM
Try not, Do or Do not
Henry Schmidt's Avatar
The most important part of the tensioner up grade is the later style wider tensioner arms with bushings. Tensioner failure is most often caused because the tensioner arm sticks to the shaft making smooth operation of the tensioner impaired.
Your best chance at long term success includes replacement of the arms.
Henry Schmidt
SUPERTEC PERFORMANCE
Ph: 760-728-3062
Email: supertec1@earthlink.net
Old 05-01-2007, 08:50 PM
