scca_ita's Avatar
Back firing? Is it bad for a motor?
I have a 3.8 with ITBs and Electomotive tech3. After hard acceleration up through the gears and then down shift with no throttle (Foot on Brake) my motor back fires a few times. Is this bad for the motor?
Old 05-15-2007, 09:24 PM
PRO Motorsports
Tyson Schmidt's Avatar
Not bad for the motor, but not great for the exhaust system.
It's likely caused by no fuel shut-off on over-run, so you're dumping fuel into the the muffler. There's occasionally enough oxygen to cause a secondary combustion in the muffler or pipes, usually due to a short, unrestricted exhaust system.
'69 911E coupe' RSR clone-in-progress (retired 911-Spec racer)
'72 911T Targa MFI 2.4E spec(Formerly "Scruffy")
2004 GT3
Old 05-16-2007, 12:50 PM
304065's Avatar
Don't you have a throttle position switch that will cut off the fuel?
'66 911 #304065 Irischgruen
‘96 993 Carrera 2 Polarsilber
'81 R65
Ex-'88 Carrera (Sold 3/29/02)
Old 05-16-2007, 01:21 PM
scca_ita's Avatar
Yes, but I am not sure it is cutting all the fuel off. I am going to have the motor put on the dyno soon to dial things in more.
Thanks for the replies.
Old 05-16-2007, 01:48 PM
