what to do to a '95 3.6l
i have a 996tt with the UMW 3b kit so i am not looking to spend stupid money for a bunch of unusable power, as my 996 is already there.
with that being said, i do want a fun car to drive. this motor is going into a 72 rsr tribute car that should weigh around ~2500lbs. as of now it has a BC rebuilt 915 with L/S. Ollie's is doing the machine work, boat tailing, shuffle pin, cross drill, etc... what else is there that i can do while the motor is apart that will be the most bang for the dollar. cams, chip, exhaust, diff crank, p&c's... i was going to use the motronic EFI. this car will be 90% street car. |
Hi:
In this order for maximum bang for the $: 1) Good chip 2) RS cams w/ good springs & Ti retainers 3) Exhaust (there are many options) 5) Mahle 102mm P/C's
Steve Weiner Rennsport Systems Portland Oregon (503) 244-0990 porsche@rennsportsystems.com www.rennsportsystems.com |
with the mahle 102 p&c's what is the displacement end up, 3.8?
and which chip do you recomend? is the vram intake worth looking at? |
Call me. Not unless you make a LOT of changes, no.
