Horse power
What is the theoretical horse power of this configuration? at the crank? at the wheel ?
2.7 case
2.7 P/C 10.5:1
2.7 crank
2.7 S heads 35mm ports, stock springs, retainers
GE 60 cams
Twin plug
Weber 40's, 36mm choke tubes, 160 mains, 170 airs, 36mm intakes
Race gas
7200 RPM limit
1970 914-6 GT Track Car
1974 IROC Track Car
1987 911 Targa 3.2
2008 BMW X5
Old 01-19-2010, 08:45 AM
My 3.0 twin plug is very similar.
I'll guess 10% reduction for displacement from my motor.
At the crank 255 HP.
Tom Butler
1973 RSR Clone
1970 911E - Sold but Never Forgotten
914-6 GT Clone
Old 01-19-2010, 11:54 AM
I think your power will be limited by your 7200 RPM. A better choice for this RPM would be GE-40 cams. I also think you need stiffer valve springs and/or titanium retainers for this RPM and this cam. I'd guess 245 HP with a good exhaust and the RPM/cams you gave. With GE-40's you'd get the same power but more torque at 4k-6k. With the GE-60's I bet you could get to 255 at 7500 RPM.
-Andy
Old 01-19-2010, 04:43 PM
3 restos WIP = psycho
kenikh's Avatar
Ditto. Wrong cams for 7200 RPM limit, If you aren't going the long side of 7500 on a regular basis, the 40s are a much better choice.
- 1969 911S
- 1980 911SC Targa
- 1979 930
Old 01-19-2010, 05:41 PM
