Gunga Galunga
Removing AC Pulley
Folks,
Is there a way to remove the AC pulley with the engine in the car? I want easy access to the "v-belt" pulley. Thanks!! |
Kartoffelkopf
Probably easier to remove the pump from it's cradle? On the 964 variants (it may be the same on earlier models) it's only 4 bolts, then swing it out the way and sit it on an old pillow/cushioning material, with hoses still connected.
1993 (MY92) 964 Turbo 3.3 - Horizon Blue - Follow my 964 Turbo project here... http://forums.pelicanparts.com/911-engine-rebuilding-forum/626572-964-3-3-turbo-efi-conversion-using-syvecs-life-racing-engine-management.html On Instagram (along with other stuff) as @spenny_.b #spennybengineproject |
Pulley
The AC pulley is cast with the crank pulley. Mid 70s if the dealer installed the AC the pulley was added separately. Sometimes you can find a single pulley but you have to remove engine mount, sheet metal and muffler to get to pulley bolt.
Bruce |
Gunga Galunga
So how does one replace the v-belt?
Removing the A/C belt first them open the fan pulley.
Bruce |
Gunga Galunga
Yea about that... I found myself forcing the belt past the engine mount bolt head. Can't be good for the belt!
