gumba's Avatar
3.2w/weber high idle
I converted my stock 3.2 to 46mm Webers & Electromotive hpv-1. After the motor is warmed up the idle is 1200-1400 rpm. I've disconnected the linkage and backed out the idle adjustment screws and it's still idling high. The idle mixture screws & air screws have been set.
The hpv-1 is set at 10 d @ 1,000 rpm. Would I back off the timing to slow the idle down?
Old 07-08-2007, 02:28 PM
North Coast Cab's Avatar
Check the throttle linkage back to the pedal. It can get hung up where it goes through the engine tin.
1985.5 944 GTS
Old 07-08-2007, 02:39 PM
gumba's Avatar
All the linkage is disconnected. The idle screws are backed off so they're not touching the throttle arms.
Harold
'79 930/DP935 (sold)
'68 VW 3.3 Turbo Crewcab
Old 07-08-2007, 03:08 PM
sww914's Avatar
I had a hard time getting 2.2 with a pair of webers to run right recently, I had to go back to the beginning and start over because everything was just a little out of whack from everyone else who had worked on the car over the last who knows how many years. I used this guide and got it dialed in right.
http://www.redlineweber.com/html/Tech/idf_adjustment_controls.htm
Old 07-08-2007, 08:51 PM
I would dial back the timing to 5 degrees BTDC. I bet this will bring your idle down to normal.
-Andy
Old 07-09-2007, 04:50 PM
Also check your idle air correction screws are all the way in.
Old 07-09-2007, 04:52 PM
