Dave Kost's Avatar
Can the early chain tensioner be rebuilt?
It is part number 901 105 050 01. I can push the piston in with my hand- not good. Also, the top half of the tensioner came apart by taking off the top snap ring. How do you get the bottom half a part? Does it come a part?
Thanks,
Dave K
Old 06-11-2015, 01:33 PM
Yes, there is a thread I have read on here. PP sells the kits. Be sure to get the guards for the tensioners..great insurance.
Bruce
Old 06-11-2015, 03:15 PM
tharbert's Avatar
Repair Kit For ""049"" And ""053"" Tensioners: 91110590101
Pelican Parts Note: Only with original hydraulic (non-oil fed) chain tensioners.
72 911T 2.4 MFI
2017 Escape SE 2.0 turbo
2020 Honda Civic Touring Sport 1.6 turbo
10' Madone 5.2/17' Lynskey ProCross
Old 06-12-2015, 05:42 AM
Try not, Do or Do not
Henry Schmidt's Avatar
Thanks,
The early tensioners can be rebuilt but it's not a great idea. the real issue surrounding early tensioner failure is a propensity for the idler/ tensioner arm to bind on the shaft causing the tensioner to fail. The cure for this binding is to run a wider tensioner arm with bushings. The early tensioners do not allow for the installation of these updated arms.
You can buy factory updated arms or you can have your arms updated by Supertec for less than half the price.
Henry Schmidt
SUPERTEC PERFORMANCE
Ph: 760-728-3062
Email: supertec1@earthlink.net
Old 06-12-2015, 06:11 AM
