Question Rod bolt stretch guage, which one?
So I have been researching rod bolt stretch gauges for my upcoming rebuild, and know I should get the ARP gauge, but cant justify the cost for only one rebuild.
Anyone have one they want to let me rent or borrow?
Does anyone have any experience with the less expensive alternatives (summit, Lunati, etc)??
Thanks for any info you can provide!
John A.
1979 Porsche 930: 3.4L, SC cams, Twin plug, Leask WUR, Custom SSI turbo exhaust, Tial WG, K27HFS, and we can't forget the Zork (short lived depending on my homeowners assoc.)
05 Boxster S: For the Track.
06 Dodge Ram 2500 Power Wagon: Tow Vehicle
Old 07-25-2007, 12:50 PM
304065's Avatar
It's a pain because a RBSG is a simple c-frame with a movable point and a dial indicator with higher gaging force to hold it on the bolt while you are making the measurements.
That said, I'm going to purchase the ARP. For me it's about time, time spent fabricating gages vs. time assembling.
'66 911 #304065 Irischgruen
‘96 993 Carrera 2 Polarsilber
'81 R65
Ex-'88 Carrera (Sold 3/29/02)
Old 07-25-2007, 01:35 PM
911quest's Avatar
This might be worth checking into...
http://www.thesamba.com/vw/classifieds/detail.php?id=428753
Tony Proasi
1969S
1957 VW Pickup
Old 07-25-2007, 06:55 PM
911 tweaks's Avatar
rod bolt stretch guage, which one
does anyone know the quality difference btwn the arp stretch guage vs. the samba one?
Also, what grade is the "Samba" line of measuring products? el cheapo, middle of the road, hi-end...? Where can one buy their stuff if so inclined?
Thanks! Bob
I live for 911 tweaks...
Old 07-26-2007, 04:24 AM
911 tweaks's Avatar
hey guys, where is the subscribe button for the threads??
thx
Old 07-26-2007, 04:39 AM
911quest's Avatar
Well the ad looks like he is selling centech which is a decent company many of the big roaming tool companys sell it (snap-on. Matco etc.)
Tony Proasi
1969S
1957 VW Pickup
Old 07-26-2007, 05:15 AM
there is something about the "LowBugget" name that worries me. anyone tried these or any of the other cost effective alternatives? Anyone interested in Buying the ARP off me if I buy one and only use it once?
John A.
Old 07-26-2007, 06:49 AM
911quest's Avatar
I think the lowbugget comes not from a quality standpoint the guy was taking inexpensive VW parts and winning drag races with them I think if you only build one or two engines in your life it might be a inexpensive option, one of many
Tony Proasi
1969S
1957 VW Pickup
Old 07-26-2007, 07:30 AM
Jeff Alton's Avatar
I use the ARP one, it works well, a few other folks have used my gauge as well and have been happy with it.
Cheers
www.turn3autosport.com
Old 07-26-2007, 10:49 AM
Walt Fricke's Avatar
Porsche Crest
I've been happy with my Summit Racing stretch gauge. The dial indicator reads to the thousandth of an inch, but the scale allows you to read to half a thousandth. If I needed more accuracy/resolution, I could purchase a more expensive dial indicator and use that, as the fixture is not specific to the indicator.
What benefit would there be to me, using this maybe once a year, to purchase something more expensive?
Walt Fricke
Old 07-26-2007, 11:34 AM
UFLYICU
ZOA NOM's Avatar
Send a message via Yahoo to ZOA NOM
I just used a micrometer. Worked like a charm.
_______________________
Racer Rix Spec911 #5
prc-racing.com
Old 07-26-2007, 07:30 PM
Jeff Alton's Avatar
Walt, I don't think there is much to chose between the fixtures. You can always change the dial indicator if you wanted a different indicator. I picked up the ARP one only because it was a great deal, and it comes in a nice case so it is not damadged when I send it to other pelicans to use. (it is well travelled )
If you want I can send it to you and you can do some back to back comparisons with your gauge and see if there is a difference......... I suspect there will not be.
Cheers
Old 07-26-2007, 11:45 PM
Irrationally exuberant
ChrisBennet's Avatar
I use a micrometer and record the prestretch length - important if you want to reuse the rod bolts. A rod bolt gage would be nice though and much quicker.
-Chris
'80 911 Nogaro blue Phoenix!
'07 BMW 328i 245K miles!
Old 07-27-2007, 03:36 AM
thx
at top of page is a box "thread tools"
Ronin LB
'77 911s 2.7
PMO E 8.5
SSI Monty
MSD JPI
w x6
Old 07-27-2007, 05:12 AM
Yes, but you have to be logged in to see it as an option.
Free will is doing what we must joyfully.
Jung
'68 912 Coupe
'82 SC sunroof
Old 07-27-2007, 08:51 PM
911 tweaks's Avatar
thanks guys I figured it out with your help! Also, you cant subscribe to a post that you reply to. You have to come back into the system & yes need to be logged in.
Old 07-28-2007, 09:54 AM
Porsche Crest
Chris
Speed was one reason I quit trying to use a mike. Since I have suitable mike calibrators, I can reset my stretch gauge accurately when measuring the bolts after use to see if they can be reused. Or at least that is my theory.
Plus my mikes are vernier. If I used them all the time I'd be quick and accurate reading them, but I don't so I am not. And I can't justify digital mikes.
It also seemed to me that using the stretch gauge, which takes advantage of the depressions on the ends of the bolts for centering things, ought somehow be a slightly better mousetrap.
Anyway, cost wasn't an issue when deciding to purchase the Summit part. And I figure anyone using the stretch method has got to figure that he'll be doing this at least a couple of more times on down the way. Stuff happens. These were Carillo rods and whatever bolts come with them (luckily not my engine)
Walt
Old 07-30-2007, 12:18 PM
304065's Avatar
Walt,
Somebody was sure careless leaving a sharpie in that engine case.
Well, I just bought the Summit Racing version for $62. It consists of a 6" piece of steel rod with two clamps. One holds an allen screw that has had the end turned down to a sharp point so it will fit in the dimple in the bolt. It's held in place by a lock nut. The other end is open, and accepts an AGD- size dial indicator (Not the European 8mm style that makes up my collection). This indicator has 0.001" divisions with a counter up to 1" total travel. I didn't measure the face yet, but I'm guessing it's AGD group 2. Nor did I measure the gaging force, but it was VERY easy to move it by hand, I don't think there's any extra spring in it. Assuming it's "Stock" such a gage is commonly available for under $10.
I'll post some photos and experience with this unit when I receive the rods, which should be soon.
'81 R65
Old 07-30-2007, 12:37 PM
Call Kevin at Kanna Motorsports. Just had a race engine built there and he has a couple of them. I asked why he had 2 of them and said that he has loaned one out before and likes to always have one avaliable....now thats what I call be preppared.
Old 07-31-2007, 05:59 PM
Jeff Alton's Avatar
Mine is on its way tomorrow to the original thread starter. It is well travelled amongst the posters on this forum. If you want to borrow it, let me know, you can have it when Ang M018 is done with it.
Cheers
Old 07-31-2007, 06:42 PM
