cly base seal
rebuilding my 91, 3.6. with upgrades ARP rod bolts, new MAHEL P&C, (24) 993 head stud's. case sealed as per Henry's method. my question is about the cyl base green O-rings. what's the best way. Threebond 1211 or Dow Corning 111.
I have both on hand. Thanks Jerry
Old 08-13-2007, 08:54 AM
Try not, Do or Do not
Henry Schmidt's Avatar
With new o-rings and new cylinders there should be no trouble with simply using an o-ring lubricant.
If there are signes of wear or cylinder movement around the case spigots use 1211.
Henry Schmidt
SUPERTEC PERFORMANCE
Ph: 760-728-3062
Email: supertec1@earthlink.net
Old 08-13-2007, 11:15 AM
Thank you Henry, I respect your knowledge. Dow 111 it will be.
Old 08-14-2007, 01:52 PM
