piston/cylinder clearance
i am checking the tolerances on my 72 E 2.4 L p+c's .
is there a correct way to do this? top or bottom? does piston orientation make a difference? waynes book specifies 0.046mm, that's .0018 "as a max! (and nothing like the GM rebuild i recently did!) a quick check with feelers was no go at 0.003" i'm planning a stock rebuild. how close to this do i have to be? new p+c's are not in the budget ($3k+ if you can find them!) thanks , bob |
Bob,
Nickasils should be .001.......Cast iron should be about .003.
Aaron. F.S. 1965 Solex engine w carbs/cleanerBurnham Performance https://www.instagram.com/burnhamperformance/ |
Bob
Check this posting on piston to cylinder clearance limits and how to measure. Can these pistons be re-used?
Tom Butler 1973 RSR Clone 1970 911E - Sold but Never Forgotten 914-6 GT Clone |
great link.
thanks guys bob |
With clearances like that who needs rings. -laugh-
.001 |
