robmog's Avatar
piston/cylinder clearance
i am checking the tolerances on my 72 E 2.4 L p+c's .
is there a correct way to do this?
top or bottom?
does piston orientation make a difference? waynes book specifies 0.046mm,
that's .0018 "as a max! (and nothing like the GM rebuild i recently did!)
a quick check with feelers was no go at 0.003"
i'm planning a stock rebuild.
how close to this do i have to be?
new p+c's are not in the budget ($3k+ if you can find them!)
thanks ,
bob
Old 08-16-2007, 03:45 PM
BURN-BROS's Avatar
Bob,
Nickasils should be .001.......Cast iron should be about .003.
Aaron. F.S. 1965 Solex engine w carbs/cleaner
Burnham Performance
https://www.instagram.com/burnhamperformance/
Old 08-16-2007, 05:08 PM
Bob
Check this posting on piston to cylinder clearance limits and how to measure.
Can these pistons be re-used?
Tom Butler
1973 RSR Clone
1970 911E - Sold but Never Forgotten
914-6 GT Clone
Old 08-17-2007, 11:15 AM
robmog's Avatar
great link.
thanks guys
bob
Old 08-17-2007, 12:03 PM
With clearances like that who needs rings. -laugh-
.001
Old 08-17-2007, 12:23 PM
