GotaT's Avatar
Send a message via AIM to GotaT Send a message via Yahoo to GotaT
Question Cylinder Base Gaskets .24 .23
In my New gasket kit for my 2.4 T my Cylinder Base Gaskets measured differently.
3 of them came in at .23
and the other
3 came in at .24
Will this Make A Difference on installation, or should I just use the same size three on Each Side ? ?
Also Anyone know off hand what the Deck Height should be for an OE 72 2.4 T
Old 09-17-2007, 07:10 PM
.01mm shouldn't make a difference. I'd use the same size all one one side. Deck height is about 1-1.5mm for all 911 engines as far as I know. I'd use these as min and max numbers.
-Andy
Old 09-17-2007, 09:20 PM
Jeff Alton's Avatar
No difference. They are cut from sheet and that is what I would consider to be well within tollerance of either the manufacturing or the end measurement.
Cheers
www.turn3autosport.com
Old 09-17-2007, 10:29 PM
No problem, just do like you already suggested, run the same size three on one side and the others three on the other bank and you'll be just fine. Your motor won't realize that one cam tower is .0004" taller than the other :-)
Charles Navarro
President, LN Engineering and Bilt Racing Service
http://www.LNengineering.com
Home of Nickies, IMS Retrofit, and IMS Solution
Old 09-18-2007, 06:28 AM
304065's Avatar
How did you measure them?
'66 911 #304065 Irischgruen
‘96 993 Carrera 2 Polarsilber
'81 R65
Ex-'88 Carrera (Sold 3/29/02)
Old 09-18-2007, 06:41 AM
GotaT's Avatar
Thanks.. I measured them w/ a digital Micrometor
Anyone confirm Eagledriver on the Deck height of being 1 - 1.5 mm ?
THANKS
Old 09-18-2007, 08:40 AM
Yup, .040-.060" is just fine for the deck height, just make sure to check clearances if you're running anything more than the stock cam to ensure you have sufficient piston to valve clearance.
Charles Navarro
Old 09-18-2007, 08:56 AM
