Life moves pretty fast.
Need injectors
Got my 3.5 built, back in the car and running
![]() ![]() .It's kinda rough at tickover with the stock motronic as it's not set up for the 3.5 with DC20 cams. I have an SDS system hooked up to run the twin plugs and injectors but I'm thinking that the stock 3.2 injectors might run out of puff at the higher rpm. Does anyone know if the 3.3 turbo uses the same injectors as the 3.2 ? Looking on Pelican I see only the one injector listed (930-606-120-00-M14) which leads me to think that it is the same for both. If I need to go bigger injectors, anyone know of a 30lb injector that fits the stock 3.2 mqanifold and fuel rails ?
Twin plugging, you know it makes sense
Less brakes, more gas!
If I'm not mistaken, the 3.3 T was a CIS controlled engine until the 964 turbo. So those injectors would be useless for you. Pretty sure you will have to go after market and I know from a different thread that finding injectors that fit the 3.2 is a real pain. Though, they were looking for similarly matched ones to OEMs...
Best Regards, Michael
Michael ![]() '82 Euro SC 'Track Rat' 22/29 Hollows, 22/22 Tarrets, Full ERPB F/R, Rennline Tri Brace, Glass bumpers, Pro 2000's, 5 pts, blah blah blah '13 Cayenne GTS |
