efhughes3's Avatar
An open and shut CASE
Not a lot of words needed. Two guys, buttoned up in about 50 minutes. Glad I didn't try this first one by myself, having the extra hands was good.
Dow 55 on o-rings:
To quote Henry Schmidt- "4 sealants equals no leaks":
Voila:
Ed Hughes
2015 981 Cayman GTS
6 speed,Racing Yellow
Past:1984 911 Targa (Ruby), 1995 993C2 (Sapphire), 1991 928S4
Old 09-22-2007, 08:52 AM
boba's Avatar
Nice, one step closer!!
Have a good cigar.
Bob
Old 09-22-2007, 10:10 AM
efhughes3's Avatar
Have a good cigar.
Bob
Hehehehe, already about a 1/4 of the way into one of Cuba's finest. Plus, I know it's 5:00 somewhere, so a cold brew to accompany it as I sit in my garage ogling my creation.....This is way fun!
Ed Hughes
2015 981 Cayman GTS
Old 09-22-2007, 10:17 AM
efhughes3's Avatar
I'm looking at my old valves and springs. I ended up getting all new exhaust valves, Aasco racing springs and Ti retainers. I was wondering if the Ti was overkill on the retainers, but when holding one of the old retainers, I'm amazed at how much "heft" they have!
Plus, my heads were lightened by having another hole machined in them:
Ed Hughes
2015 981 Cayman GTS
Old 09-22-2007, 10:25 AM
boba's Avatar
Outstanding idea!
My only critique, I think a good single malt would better enhance that cigar.
Old 09-22-2007, 10:44 AM
efhughes3's Avatar
Some more pics, clean cam towers and the sealing ridge/groove set up in the cylinders and heads.
Ed Hughes
2015 981 Cayman GTS
Old 09-22-2007, 11:36 AM
A Wrench
SeanR's Avatar
Very nice Ed. Well done.
Old 09-22-2007, 11:51 AM
Less brakes, more gas!
euro911sc's Avatar
Ed!!
Great work! I'm hoping to get there this month myself!
Just one small detail I think you may have missed... I believe there is supposed to be a ground strap/wire attached along the top ridge of the case. I could be wrong, though based on your engine... just that there is one on my sc and I'm using it as reference. I'm sure its no big deal putting it on once everything is nice and dry.
Best regards,
Michael
Originally Posted by efhughes3 View Post
Michael
'82 Euro SC 'Track Rat' 22/29 Hollows, 22/22 Tarrets, Full ERPB F/R, Rennline Tri Brace, Glass bumpers, Pro 2000's, 5 pts, blah blah blah
'13 Cayenne GTS
Old 09-22-2007, 03:12 PM
304065's Avatar
Ed, nice! Very very well done.
Michael's right, you might want to put the ground strap on, and if your engine had a lifting lug, put that on too (ahead of the breather.)
Looking good!
'66 911 #304065 Irischgruen
‘96 993 Carrera 2 Polarsilber
'81 R65
Ex-'88 Carrera (Sold 3/29/02)
Old 09-22-2007, 05:28 PM
efhughes3's Avatar
I may have a ground strap there, can't remember. I'll look at my pics. I'm going to get to the breather, oil pistons and springs, t-stat, ramps, etc next I'll look at it then.
Ed Hughes
2015 981 Cayman GTS
Old 09-23-2007, 01:17 PM
Try not, Do or Do not
Henry Schmidt's Avatar
Nice job !!
Feels good doesn't it?
Cheers
BTW: any more drinking references and a walk with Bill W might be in order
Henry Schmidt
SUPERTEC PERFORMANCE
Ph: 760-728-3062
Email: supertec1@earthlink.net
Old 09-23-2007, 01:54 PM
Tom '74 911's Avatar
Hi Ed -
That's looking really great! It must be satisfying to make some good progress.
I sent you a PM w/a question.
Tom
'74 911 Red Sunroof Coupe, 3.6L, etc...
'76 912 Yellow SPEC 911/911CUP
Old 09-23-2007, 05:51 PM
timeless beauty
rcaradimos's Avatar
subscribed
Thanks for posting your work
Old 09-26-2007, 05:47 PM
efhughes3's Avatar
Thanks guys!
It does feel good, and the case being together now gives me a solid foundation to build on as my goofy travel/work schedule allows.
One thing my travel did allow, was for me to go by Supertec earlier today to pick up some parts in person from Henry. What an awesome shop and in a beautiful location!
Ed Hughes
2015 981 Cayman GTS
Old 09-26-2007, 08:44 PM
You are making me jealous.
Nice job. I hope to do the same once enough funds are saved for the machine work.
How did you clean your pistons?
Old 09-27-2007, 08:48 AM
efhughes3's Avatar
I had them cleaned at Ollie's-tanked and blasted, I believe.
Ed Hughes
2015 981 Cayman GTS
Old 09-27-2007, 09:26 AM
Ten minutes in the oven @ 180 F and a thin coat of Easy-Off oven cleaner is the best way we have found for cleaning pistons. If you use the lemon scented your wife won't notice what you're doing.
Try it, you'll be amazed.
Henry Schmidt
Ph: 760-728-3062
Old 09-27-2007, 09:49 AM
abit off center
cgarr's Avatar
Henry is such the homemaker
______________________
Craig
G2Performance
Old 09-27-2007, 10:18 AM
304065's Avatar
Ed, I notice you are using DC 55 instead of 111 on the seals. From reading the product sheet that actually looks like a more suitable lubricant than 111. Can you explain how you chose this? Did it swell the seals at all?
'81 R65
Old 09-27-2007, 10:25 AM
efhughes3's Avatar
Well, I could say that after hours and hours of exhaustive research, I deduced that 55 was the stuff to use.
Or, I could come clean and tell you that Henry recommended it to me. It what he's now recommending for this task. He stocks it, along with all of the other recommended case sealants.
It's hard to say if I saw any swelling, as I applied the stuff to the o-rings, and didn't disturb them prior to putting the thru bolts in.
Ed Hughes
2015 981 Cayman GTS
Old 09-27-2007, 06:32 PM
