GotaT's Avatar
Send a message via AIM to GotaT Send a message via Yahoo to GotaT
Cylinder Sealing Surface Measurement
Ok guys Heres a Brief Overview for your understanding
.. Ive gotten my measurements for my 2.4t Heads and Cylinders.
Its my understanding that the heads overall distance should be 3.326 and all 6 of mine Check in Right around that number at 3.325.
Now the Sealing Surface on the T Heads came in at an average of .097 which is also within tolerance of .080 - .100
ONTO the CYLINDERS. >>>>
They all Measured correctly on the Overall distance ranging from 3.363 in to 3.368 in
??? HOWEVER, ????
The step to the Sealing Surface on the Cylinders seemed a little Low ranging from .110 to .114 When I believe they should be within .124 - .140
What Should I do? ? ?
Old 09-23-2007, 06:31 PM
304065's Avatar
What do you mean by overall distance? From where to where measured with what?
'66 911 #304065 Irischgruen
‘96 993 Carrera 2 Polarsilber
'81 R65
Ex-'88 Carrera (Sold 3/29/02)
Old 09-24-2007, 05:43 AM
abit off center
cgarr's Avatar
You measuring from the cam tower sealing surface (on the head) to the cylinder surface? Thats the one that has to be the same all the way around.. Thats a quick way to tell if they have been cut too..
______________________
Craig
G2Performance
Old 09-24-2007, 06:00 AM
I surface grind cylinders all the time to get the head to deck length within .0002", so that is one option for getting the heights right on the cylinders. As far as the groove depth, if you have a spec you could always have the groove remachined. It seems as though you have lots of variation - were these all off one engine?
Charles Navarro
President, LN Engineering and Bilt Racing Service
http://www.LNengineering.com
Home of Nickies, IMS Retrofit, and IMS Solution
Old 09-24-2007, 06:34 AM
GotaT's Avatar
Yes, measuring from the Cam tower sealing surface to the mating surface on the Cyl.... here they measure all the same and correct.
Old 09-24-2007, 07:03 AM
GotaT's Avatar
These to my knowledge all came from the same engine. .. I cant understand why the Cylinders overall measurment is correct but the Step distances are different.. ??
Old 09-24-2007, 07:06 AM
