-   -   Aurel`s engine rebuild thread (http://forums.pelicanparts.com/911-engine-rebuilding-forum/369745-aurel-s-engine-rebuild-thread.html)
Aurel 10-05-2009 05:49 PM
Originally Posted by mca (Post 4937034)
How were your rockers? Any shifting? I am at roughly 9k on my rebuild and plan on adjusting the valves at 11k. Just curious to know if you rechecked the rocker torque.
I didn`t check. Will do when I drop it to fix a few leaks, someday. Or maybe at the next valve adjustment, if I remember. This one didn`t go too well (see thread) so I was in a bit of hurry to button her back up.
OldTee 10-06-2009 06:31 AM
Where are your leaks coming from? Possible cam tower leak? Either I didn't use enough sealant or some oil got on the surface on the 3.2 and I'm going to have to pull it and seal it over. Big pain.
Charlie V 10-06-2009 06:47 AM
Interesting question........
I did valve spring work earlier this year and had one of my rocker shafts loosen up after some 2500 kms. Found this when I readjusted the valves. Freaked me out a little. I rechecked after 1000 kms and things are good.
Aurel 10-06-2009 08:02 AM
I`ve got one leak at the oil cooler, and another one at the crank pulley seal. Nothing major, but annoying. Cam towers are fine :).
khamul02 02-22-2011 11:55 PM
What is the latest? How is the engine holding up after a few years?
CobraJet 03-21-2013 03:26 AM
I just read this thread, very nice work and thank you for the full photo step by step. I'm sure that it will help more than one person contemplating doing this them selves but hesitating.
So, how is she running now? Did this all change your gas mileage for the better?
Aurel 03-21-2013 05:08 AM
Go to my new thread for the latest (bad) news:
http://forums.pelicanparts.com/911-engine-rebuilding-forum/739457-rebuild-2-a.html
