930s rule the wasteland
h20cooled7's Avatar
Send a message via AIM to h20cooled7
Question chain ramps?
Im reramping and putting carrera tensioners in my 80 930 . How do I know when my 4 inner ramps are seated on the pins? I dont want to put it back together until Im sure its right.
1980 930 Turbo
1993 Corrado
1983 944
1984 944
2001 VW golf TDI
Old 10-17-2007, 04:41 PM
When the ramps line up with the chains and the bolt/pins are tight then they are seated. You'll find that after you put the bolts/pins in they will push the ramps against the back of the case. You then have to move the ramps toward the middle of the opening until they snap into place. I think I used a fat screw driver to pry the ramps toward the middle of the opening.
-Andy
Old 10-17-2007, 06:29 PM
snap the bolts into the chain rams once or twice before you install them. I then held them against the block as tight as possible until they snapped in. A little bit of aerosol silicon in the ramp holes helped too
John A.
1979 Porsche 930: 3.4L, SC cams, Twin plug, Leask WUR, Custom SSI turbo exhaust, Tial WG, K27HFS, and we can't forget the Zork (short lived depending on my homeowners assoc.)
05 Boxster S: For the Track.
06 Dodge Ram 2500 Power Wagon: Tow Vehicle
Old 10-17-2007, 07:29 PM
h20cooled7's Avatar
very cool , thank you!
1980 930 Turbo
1993 Corrado
1983 944
1984 944
2001 VW golf TDI
Old 10-18-2007, 10:34 AM
