Work in Progress
Rich76_911s's Avatar
Weber Gaskets
I order a gasket set for my webers a long time ago and now that I am putting the gaskets on one inparticular is not fitting. I'll attach a picture of what I am having problems with.
The gasket ripped where the green arrows are and it overlaps and goes into places it shouldn't where the red arrows are.
Am I installing these incorrectly? Should gaskets be soaked or treated to make them more pliable prior to installation? Or what is happening here? I've flipped them upside down to see if that fixed the problem but no go on that fix.
Thanks,
Rich
"The reason most people give up is because they look at how far they have to go, not how far they have come." -Bruce Anderson via FB
-Marine Blue '87 930
Old 10-26-2007, 08:51 AM
304065's Avatar
Weber 40IDL 3C rebuild gaskets
'66 911 #304065 Irischgruen
‘96 993 Carrera 2 Polarsilber
'81 R65
Ex-'88 Carrera (Sold 3/29/02)
Old 10-26-2007, 09:28 AM
Work in Progress
John,
Thanks for the link. I've read through it before and read through it again, but there doesn't seem to be any solution other than soaking the gasket in water. Maybe I will give that a shot.
Rich
Old 10-26-2007, 09:40 AM
