id911T's Avatar
Letting the engine sit on the heat exchangers
Quick question,
Is it going to hurt the heat exchangers on my 2.2 engine if I put it on a pallet with them still bolted to the engine? Can they take the weight of the engine without damage?
Stephen
GruppeB #906
1970 911T
Old 10-26-2007, 12:28 PM
Komenda Fan's Avatar
Didn't seem any worse for wear when we dropped my buddies 2.4 and left it on its HE's for a couple of months.
2012 911 Black Edition Cabriolet
2008 Cayman S Grey on Black - flooded, written off
1977 930 Turbo Carrera Black on Red #411
1987 951 Black on Black - sold to make room for the 930
1972 911 2.7 - I regret selling her every single day....
Old 10-26-2007, 12:35 PM
id911T's Avatar
Ok, thanks a bunch.
Stephen
GruppeB #906
1970 911T
Old 10-26-2007, 01:02 PM
304065's Avatar
This is done all the time, let it down gently.
'66 911 #304065 Irischgruen
‘96 993 Carrera 2 Polarsilber
'81 R65
Ex-'88 Carrera (Sold 3/29/02)
Old 10-26-2007, 01:22 PM
Just don't let it sit on the ground/floor. The heat exchangers will rust over time.
Tom Butler
1973 RSR Clone
1970 911E - Sold but Never Forgotten
914-6 GT Clone
Old 10-26-2007, 02:12 PM
OldTee's Avatar
They slide real good on large boards used as ramps to get the damn things into the pu truck!
Old Tee
all 911s sold
Old 10-26-2007, 05:07 PM
I've rested my engine on the heat exchangers before and it's been fine. My question is: what do you do if you have headers instead of heat exchangers? I would assume that you can't let it sit on the tubing.
Old 10-26-2007, 05:33 PM
If you get some 16mm bright steel rod and cut it into four equal short lengths you can poke each one through the holes in the heat exchangers that allow access to the heat exchanger retaining nuts. I also used a cable tie to keep the steel rods in place. Using this technique I did not mark my newly painted heat exchangers at all. I hope this makes sense...
Regards
Old 10-27-2007, 12:54 PM
Steve, interesting idea.. I guess then the weight lands on the top of the header bolts where the hex feature is... right? I've been using a few towels... when I set the engine down on the rolling pallet I put folded over towel strips down for each hex.
Old 10-30-2007, 08:45 AM
