Letting the engine sit on the heat exchangers
Quick question,
Is it going to hurt the heat exchangers on my 2.2 engine if I put it on a pallet with them still bolted to the engine? Can they take the weight of the engine without damage?
Stephen GruppeB #906 1970 911T |
Didn't seem any worse for wear when we dropped my buddies 2.4 and left it on its HE's for a couple of months.
2012 911 Black Edition Cabriolet 2008 Cayman S Grey on Black - flooded, written off 1977 930 Turbo Carrera Black on Red #411 1987 951 Black on Black - sold to make room for the 930 1972 911 2.7 - I regret selling her every single day.... |
Ok, thanks a bunch.
This is done all the time, let it down gently.
'66 911 #304065 Irischgruen ‘96 993 Carrera 2 Polarsilber '81 R65 Ex-'71 911 PCA C-Stock Club Racer #806 (Sold 5/15/13) Ex-'88 Carrera (Sold 3/29/02) Ex-'91 Carrera 2 Cabriolet (Sold 8/20/04) Ex-'89 944 Turbo S (Sold 8/21/20) |
Just don't let it sit on the ground/floor. The heat exchangers will rust over time.
Tom Butler 1973 RSR Clone 1970 911E - Sold but Never Forgotten 914-6 GT Clone |
They slide real good on large boards used as ramps to get the damn things into the pu truck!
Old Tee all 911s sold |
I've rested my engine on the heat exchangers before and it's been fine. My question is: what do you do if you have headers instead of heat exchangers? I would assume that you can't let it sit on the tubing.
If you get some 16mm bright steel rod and cut it into four equal short lengths you can poke each one through the holes in the heat exchangers that allow access to the heat exchanger retaining nuts. I also used a cable tie to keep the steel rods in place. Using this technique I did not mark my newly painted heat exchangers at all. I hope this makes sense...
Regards Steve |
Steve, interesting idea.. I guess then the weight lands on the top of the header bolts where the hex feature is... right? I've been using a few towels... when I set the engine down on the rolling pallet I put folded over towel strips down for each hex.
