Anyway to idenitify a MFI spacecam?
I just bought a complete MFI system which the guy selling claims was on a 2.4T (confirmed by the pump number) which had been rebuilt and modified to a 2.7 with S cams by Stoddard. Anyway to confirm this when I get the parts?
Robert
Currently Porsche less (but the wife has 2)
Old 11-05-2007, 05:47 PM
304065's Avatar
not externally without a volume test unless gus has records
'66 911 #304065 Irischgruen
‘96 993 Carrera 2 Polarsilber
'81 R65
Ex-'88 Carrera (Sold 3/29/02)
Old 11-06-2007, 12:28 AM
Do you have a procedure and spec's for a volume test? I assume rotate pump at x revoultions should produce y volume in z time from one injector?
Robert
Old 11-06-2007, 07:58 AM
304065's Avatar
Procedure is probably in the MFI repair instructions. . . I don't know what the specifications are, certainly Gus has them but he might not let them out. Would be expressed as cc per number of revolutions. This may help, for the 911E cam. . . how's your German?
'81 R65
Old 11-06-2007, 10:08 AM
Note 3 seems to indicate that each cam has a different number stamped on it. Maybe that can be used to identify the type.
Robert
Old 11-06-2007, 06:57 PM
304065's Avatar
Yes, once you have the pump apart.
'81 R65
Old 11-07-2007, 06:14 AM
Ey, there's the rub isn't it.
Robert
Old 11-07-2007, 04:38 PM
304065's Avatar
Aye: the best-laid schemes o' mice an' men /gang aft agley
'81 R65
Old 11-07-2007, 06:00 PM
