Vote on my new motor build/swap! Spend my money!
Hello Pelicans,
I was about to rebuild my worn out 71 2.2t to a 2.4e when a 74 2.7 cis motor landed in my lap. Please weigh in and let me know what you're opinion is. Here's what you need to know. Car is in good shape with tight and upgraded suspension, s brakes. I plan on using the 2.7 and saving the 2.2 2.7 has motor side components of cis the 2.7 needs a rebuild (studs) but is in good shape otherwise I already have backdated ssi's I want a spirited street car, prefer "e" type curves car will be a weekend driver using original '71 901 (911) trans don't want an s type all top end car like good throttle response west coast so gas is 91 at best I have peripheral parts needed. oil cooler, ignition etc. i don't have a trust fund So knowing that, info here are your choices (levity appreciated, variations welcomed): 1. Just rebuild the 2.7 stock, run the cis. It'll be sportier than your bagged 2.2t popcorn machine. You'll have better mileage and it'll be cheap(er). You're gonna kill your knuckles putting in that return fuel line though. 2. You've got the engine apart... may as well put in some higher comp pistons and a 964 cam. you'll get a bunch more ponies and it won't cost that much. Better mileage too. That fuel lines gonna be a ***** though. 3. CIS Sucks. Higher comp pistons, e cam. Get your self a shiny set of PMO's. Who cares about mileage? it's a weekend car and your wife drives a prius. You live in southern california you can proabaly make it a few more years before you pay for that new roof. 4. MFI, EFI, dual plugs, engine management etc etc. (voting for this choice requires a $1000 donation). Thanks for any comments!
1971 911E 2.7RS interpretation -- Signal Orange baby! Last edited by whackit; 11-09-2007 at 10:35 AM.. |
None of the above-- rebuild "t" motor with new Mahle Nikasil 84mm "E" cylinders and DC "mod-e" cams, re-jet Zeniths for original appearance. The case mods on the 2,7 alone will be very expensive.
'66 911 #304065 Irischgruen ‘96 993 Carrera 2 Polarsilber '81 R65 Ex-'71 911 PCA C-Stock Club Racer #806 (Sold 5/15/13) Ex-'88 Carrera (Sold 3/29/02) Ex-'91 Carrera 2 Cabriolet (Sold 8/20/04) Ex-'89 944 Turbo S (Sold 8/21/20) |
Less brakes, more gas!
Trade your 2.7 for another 2.2t or 2.4 that will bolt right up so you can swap engines at will... then build your new motor exactly how you like it whilst still driving the nice car. Swap in the new motor and rework your old one
so you can go back stock at will.-michael
Michael ![]() '82 Euro SC 'Track Rat' 22/29 Hollows, 22/22 Tarrets, Full ERPB F/R, Rennline Tri Brace, Glass bumpers, Pro 2000's, 5 pts, blah blah blah '13 Cayenne GTS |
I was under the impression... that the 74 2.7 was a straight bolt up to the 901 (911) they both have 5R cases. so I think I will be able to execute euro911scs dasterdly plan.
1971 911E 2.7RS interpretation -- Signal Orange baby! Last edited by whackit; 11-09-2007 at 01:37 PM.. |
Max Sluiter
I vote MFI- the throttle response is great and the car just zings. I have a T spec pump for sale. It will need freshening, I think.
1971 911S, 2.7RS spec MFI engine, suspension mods, lightened Suspension by Rebel Racing, Serviced by TLG Auto, Brakes by PMB Performance |
Didn't they start the 915 in '72? I was thinking you can't mount a 915 based engine onto a 901 w/o some help, but I love to be corrected here so I don't look like a fool face to face ![]() Best regards, Michael
1971 911E 2.7RS interpretation -- Signal Orange baby! |
3 restos WIP = psycho
Neither. Get some Mahle 2.2S P/Cs, use that 70.4mm crank and rods from the 2.7 and get a set of John Dougherty's mod-solex cams w/ carbs. This combo is a hi-comp 2.4L smile machine (premium gas only, though). It would also allow you to use your T ports with no penalty.
- 1965 911 - 1969 911S - 1980 911SC Targa - 1979 930 |
don't want an s motor... thanks tho
![]() -michael
I think you misunderstand. An 'S' motor refers to having 'S' cams, which is what determines character/power delivery. 'S' pistons just mean more compression, which with E or Solex cams improves performance all around. The motor specs I mention are better for the scenario you called out than any you suggested. Just trying to help.
I have 2 911 Ts. Also some other things you'll have a marelli dist, change that one and KEEP IT LIKE GOLD, put a BOSCH hell a lot easier ( ). Good luck and tell how's it going with the project
There is no substitute |
