Anarchist Extremist
Leak Down, what should I look for?
I will be doing a leak down on my car tomorrow (freshly rebuilt 3k miles ago), it stil smokes intermitently that is why. 2.7CIS stock re ringed cylinders not replaced.
I am wondering what I should be looing for and what should throw a red flag. any tech articles written on this subject that anyone knows about? thanks Chris
80 SC Coupe 00 Tundra (Tow Rig) 00 Audi A6 Avant (wifes rig) 03 Wife ('71 typ Spezial) 05 Kid (MENSA prototype) |
Do a compression check first.
It's possible the rings haven't seated. If the compression is low anywhere, spray in some oil, I use WD-40, then recheck. If the compression rises significantly after spraying oil, the problem is a worn out cylinder, or a need to run a grape hone lightly through the cylinders. If the compression is fine, likely a valve guide issue. Ask me how I know. Nikasil or Alusil?
DOUG '76 911S 2.7, webers, solex cams, JE pistons, '74 exhaust, 23 & 28 torsion bars, 930 calipers & rotors, Hoosiers on 8's & 9's. '85 911 Carrera, stock, just painted, Orient Red |
Anarchist Extremist
I did have the heads re-built How can I tell what the problem is?
Chris
Chris,
"If the compression rises significantly after spraying oil, the problem is a worn out cylinder, or a need to run a grape hone lightly through the cylinders." Simply changing rings usually do not reseal properly.
