-   -   Twin Plug?? (http://forums.pelicanparts.com/911-engine-rebuilding-forum/378939-twin-plug.html)
safe 11-27-2007 03:09 PM
Originally Posted by TimT (Post 3609716)
With three ignition drivers you can easily control the ignition for a twin plugged six
you need two three channel ignitors, the output signal from the ECU's ignition drivers is split and feeds one each of the ignitors, each ignitors output goes to a twin tower coil.
This schematic from show how to wire it , you just use another whole set up like this fore the other set of plugs.
we use Bosch 0227 100 203 ignitors
Nice, those are affordable and plentiful from the junkyard.
What coils do you use?
