3.2 engine barn find. Now what ?
Hi guys,
I found a complete 3.2 engine in a old house!
It missing the AFM,DME,DME wiring harness and the coil.
I was covered in dust/mud and I think the following.
Removal of the intake as a unit,clean and check injectors.
Removal of engine tin.
Removal of Fan & Fan shroud.
Degreasing / Clean of all parts incl. longblock.
Check/Adjsut valves.
New spark plugs.
How sounds the idead to have it rotated with the starter w/o spark plugs (and to spray a little kroil inside the cylinders) ???
Thanks!
Jim
Old 12-29-2007, 08:46 AM
gigem75's Avatar
sure why not, comp check too
Why can't I find those?
Old 01-01-2008, 07:46 AM
3.2 CAB's Avatar
I could not tell from you post if you have tried to turn it over by hand yet, to make sure that it is not locked up? That would be one of the first things that I would do after cleaning all the crap off of the engine, and then removing the spark plugs, before I would try to turn it over by hand to make sure that it does not have any major problems, like a rod (or other part) going somewhere that it is not supposed to be going. Good luck on the find!!
84' Steelslantnose Cab.
1953 Dodge B-4-B-108" 90,127 miles
1953 Dodge B-4-C-116" 58,146 miles
1954 Dodge C-1-B8-108" 241V8 POLY
1973 Roadrunner 440-SIX-PACK*
1986 F-250 Super Cab-460 V8 tow
Newest additions-
Matching numbers 1973 340 Road Runner!!
1948 Dodge B-1-F-152" 1-1/2 ton Dump body, 39,690 miles
others...
Old 01-01-2008, 09:10 AM
sww914's Avatar
Torque the Head Studs before you go too far. I saw a barn find 3.2 that had mice living on top of it. Their acidic urine ran down the case and corroded the head studs and they broke, right next to the case.
Old 01-01-2008, 11:51 AM
