efhughes3's Avatar
Originally Posted by AngM018 View Post
Looking good Ed!! I had the same oil leak on mine when I got her started, it was an easy fix. After you replace the fuel lines, and you still have the issue of it trying to start for awhile, and sputtering at the end, double check TDC and the dizzy rotor (by pulling spark plug on #1). I spent days trying to figure out why my engine was doing this, and I finally double checked the rotor after pulling valve covers to make sure my cams weren't 180 out(they weren't). I had pulled the dizzy so many times (replaced green wire from hell) I had the rotor 180 out. She then fired right up!
P.S. it is so much easier to pull the tranny w/ the engine next time you take the engine out. Especially when you have that scissor jack set up (I am envious)
John, I may have a similar issue on timing, but I think I may be off a tooth on the dizzy. It runs, but only gets "good combustion" on three cylinders. See my new thread on the subject: http://forums.pelicanparts.com/911-engine-rebuilding-forum/381416-got-half-my-new-motor-running-please-feel-free-weigh-ideas.html#post3633488
Actually, now that I've done it, I think that removing the engine without the trans is a bit simpler and faster.
Ed Hughes
2015 981 Cayman GTS
6 speed,Racing Yellow
Past:1984 911 Targa (Ruby), 1995 993C2 (Sapphire), 1991 928S4
Old 12-08-2007, 01:27 PM
Ed just want to know where you get the sci jack and how much ?
Old 03-09-2008, 01:27 PM
efhughes3's Avatar
asedeals.com....about $1400
Ed Hughes
2015 981 Cayman GTS
Old 03-09-2008, 05:30 PM
Beautiful engine Ed, beautiful. May I ask what type of air cleaner you're running?
O2 In Sully We Believe
Old 03-09-2008, 06:45 PM
efhughes3's Avatar
Thanks, It's a K&N or similar....can't truthfully remember where I got it.
Ed Hughes
2015 981 Cayman GTS
Old 03-11-2008, 08:28 PM
3.2 CAB's Avatar
Ed, I must commend you on the great looking engine. Hopefully by now you have the bugs out of it. Also, I really like your taste in wheels! A++++ Tony.
84' Steelslantnose Cab.
1953 Dodge B-4-B-108" 90,127 miles
1953 Dodge B-4-C-116" 58,146 miles
1954 Dodge C-1-B8-108" 241V8 POLY
1973 Roadrunner 440-SIX-PACK*
1986 F-250 Super Cab-460 V8 tow
Newest additions-
Matching numbers 1973 340 Road Runner!!
1948 Dodge B-1-F-152" 1-1/2 ton Dump body, 39,690 miles
others...
Old 03-11-2008, 10:28 PM
efhughes3's Avatar
Thank you Tony. The bugs are out-did my first real track weekend in a year this past. I love the cams....better mid range torque, and great pull at top end to 7k. I do like the wheels, but when a certain someone in BC gets my new wheels done, these are history.
Ed Hughes
2015 981 Cayman GTS
Old 03-12-2008, 06:49 PM
