Race gas
My rebuild this winter includes some Mahle 10.4:1 pistons. The motor is single plug and I'm gonna need race gas. So, what octane. I'm looking at Sunoco 100 unleaded.....good enuff? Sunoco 104 which may be leaded?
JPIII
Early Boxster
Old 12-03-2007, 08:15 AM
Sunoco 100 is fine; Sunoco 104 is also good stuff,.....both are unleaded.
Twin-plug that thing!!!!!
It pays big dividends in torque & throttle response.
Steve Weiner
Rennsport Systems
Portland Oregon
(503) 244-0990
porsche@rennsportsystems.com
www.rennsportsystems.com
Old 12-03-2007, 08:57 AM
Who.... me the CSOB?
The thing is a black hole in a parking lot........
Between the rebuild & an LSD, I'm tapped out.
JPIII
Early Boxster
Old 12-03-2007, 10:57 AM
Britain Smith's Avatar
Is the improvement in torque and throttle response a function of the twin plug or the higher compression?
-Britain
'69 912 w/ 2.3L Type-4 Turbo Engine
'74 914 1825lbs, JDM Subaru STi Spec-C Engine, Lotus Suspension, 930 Trans.
'80 924 AAN 5-Cyl, Corvette C5 Transaxle - Team UBoot Rennwerks
-- www.britainracing.com --
Old 12-03-2007, 12:35 PM
-Britain
Both!!!!!
Two flame fronts and almost half the necessary ignition advance make a more efficient engine.
Added compression makes more torque, too.
Aside from the initial $$$, there is nothing bad about it and given the cost of $7-8/gallon race fuel, its a good investment.
Steve Weiner
Rennsport Systems
Portland Oregon
(503) 244-0990
Old 12-03-2007, 04:28 PM
For JP's motor, will the tuning for race gas be significantly different than pump gas give that we are running 10.4:1 and single plug.
-Britain
Old 12-03-2007, 05:17 PM
North Coast Cab's Avatar
At least get the heads drilled for twin plugs, only a few hundred dollars. Then down the road you can add the ignition set-up to take advantage of it.
1985.5 944 GTS
Old 12-03-2007, 05:50 PM
The long block is together and it ain't coming apart......well, unless it does self disassembly.
Hay, it's a low rent 914 AX car not one of them purdy 9elebens.
JPIII
Early Boxster
Old 12-03-2007, 05:59 PM
-Britain
Not appreciably,...........
Steve Weiner
Rennsport Systems
Portland Oregon
(503) 244-0990
Old 12-03-2007, 08:21 PM
camgrinder's Avatar
What camshafts are you running? and in what size engine? What octane pump gas do you have up there?
I love the Sunoco 100 GT.
John Dougherty
Dougherty Racing Cams
Old 12-05-2007, 03:51 PM
Solex cams. in a 2.7L. a very good Autocross cam, I've found. It's wide power band is just the ticket. Mahle P/Cs @ 10.4:1. Our pump premium is 93.
It's not as pretty as the good Mr. Cramer's. ....
JPIII
Early Boxster
Old 12-05-2007, 07:00 PM
Another. One of the cams was NOS in the original package!
The other had been "touched up" by Web cams.
Note the plugged centeroiler passages. .....
JPIII
Early Boxster
Old 12-05-2007, 07:08 PM
Lookin' good, Gents.........
Steve Weiner
Rennsport Systems
Portland Oregon
(503) 244-0990
Old 12-05-2007, 11:14 PM
