Oil for break-in on rebuilt 3.2??
I've heard pros and cons for synthetic and non-synthetic, along with numerous brands. Very confusing...
Any suggestions?
Thanks.
- Sean
'87 Carrera
Old 12-07-2007, 03:54 PM
I always recommend using a non-synthetic oil for break in. There are numerous conventional oils marketed specifically for break-in with additional Zn and P, with signifantly less detergents or none at all. I usually use the Brad Penn Break-in 30WT for the first 200 mi then switch over to their 20w50. If dynoing the engine, a few good pulls and cam break-in on the 30WT break-in oil is more than sufficient. I don't recommend using a synthetic until at least 1,000 mi, if not more, on a rebuild. But that's just me.
Charles Navarro
President, LN Engineering and Bilt Racing Service
http://www.LNengineering.com
Home of Nickies, IMS Retrofit, and IMS Solution
Old 12-07-2007, 04:52 PM
+1 on brad-penn
John A.
1979 Porsche 930: 3.4L, SC cams, Twin plug, Leask WUR, Custom SSI turbo exhaust, Tial WG, K27HFS, and we can't forget the Zork (short lived depending on my homeowners assoc.)
05 Boxster S: For the Track.
06 Dodge Ram 2500 Power Wagon: Tow Vehicle
Old 12-07-2007, 09:13 PM
just me
paulgtr's Avatar
Send a message via Yahoo to paulgtr
never heard of brad penn oil.
why is it different or better than other oils?
1975 911s, 3.2l and 915 transmission front oil cooler RUF replica bumper ducktail and SC rear flares SW chip ssi's m&k 2 in 1 out sc front calipers PF 97 pads fuchs 16 x 7 and 8 225/ 245 toyo ra-1s 22/29 torsion bars 25mm Charlie Bars Neatrix bushings lowered and corner balanced DAS bolt in roll bar kirkey seat 5 point harnesses.
http://www.hairydoggrrrage.com/
Old 12-08-2007, 10:51 PM
Here, you can catch up on our current discussion about oils, if you missed the thread:
Ultimate Motor Oil Thread or Why we hate CJ4/SM oils
http://www.lnengineering.com/oil.html
Charles Navarro
Old 12-09-2007, 05:54 AM
Question Brad Penn oil
Thanks Charles... pick up a few cases. I was told that a good break-in oil for the 3.2's is the good 'ol Rotella T. Is that not the case any more?
- Sean
'87 Carrera
Old 12-17-2007, 03:39 PM
Racer
preston_brown's Avatar
And, why use the straight 30W for break-in, rather than the multi-viscosity stuff?
Preston Brown
Street: 2009 911 Carrera S Coupe | 2015 Cayenne S | 1995 Audi ÜrS6 (unicorn)
1965 356 C Coupe | 2010 F250 (support vehicle)
Race: 1994 964 GT2/1 | Various 944s | 2016 Superlite SLC | 2007 997 Carrera
Old 12-17-2007, 04:03 PM
I'm not actually sure... I'll leave it to the experts on here.
- Sean
'87 Carrera
Old 12-17-2007, 04:15 PM
efhughes3's Avatar
I'm no expert, but a key in break-in is to get a good film between the wearing components, and the lighter 30W may accomplish this better, as well as washing away the particles. The BP break-in oil is chock full of vitamins that are good for new motors, and not full of detergents which you don't need.
Ed Hughes
2015 981 Cayman GTS
6 speed,Racing Yellow
Past:1984 911 Targa (Ruby), 1995 993C2 (Sapphire), 1991 928S4
Old 12-17-2007, 04:32 PM
